R55 Torx size for seat
Old Nov 26, 2010 | 07:03 PM
Morry's Avatar
Morry
Torx size for seat
I am trying to install a center armrest in my 2008 Clubman S. What size is the torx bit needed to remove the rear bolt on the front seat? Thanks.
Old Nov 27, 2010 | 06:14 AM
bluefox280's Avatar
bluefox280
It's a Torx T40 bit / socket you're needing:
* https://www.northamericanmotoring.co...r-armrest.html
- Erik
Old Nov 27, 2010 | 12:49 PM
Morry's Avatar
Morry
Thanks!
Old Nov 29, 2010 | 08:55 PM
Morry's Avatar
Morry
Eric,
Today I put in the armrest. Thanks to you I borrowed the correct size Torx bit and had it in about 30 minutes. I am not sure if I like it, though. I'll give it some time and see if I get used to it.
Old Nov 29, 2010 | 09:06 PM
bluefox280's Avatar
bluefox280
Good to hear; easy installs are fun.
I removed my OEM NA-spec armrest from my Clubby about a month ago.
It's been the better interior "upgrade" so I can easily shift and reach into the rear seats.
-Erik
Old Nov 30, 2010 | 05:10 AM
yetti96's Avatar
yetti96
I too am thinking about doing this. I do use the arm rest a little but am doubtful I will miss it in a week on not having it. Maybe something to do tonight, removal.
Old Nov 30, 2010 | 07:27 AM
strobeyprobey's Avatar
strobeyprobey
Just as side note related to the seat, make sure you disconnect your battery before unplugging the seat harness. The airbag computer will need to be reset by a dealer (or if you are crafty you can do it yourself with DIS or ISTA).
gsredmini
Oct 20, 2015 07:43 AM
newowner
Sep 15, 2015 07:18 AM
SeattleF56
Sep 3, 2015 03:01 PM
Sep 3, 2015 10:45 AM
Ntety
Sep 2, 2015 08:39 PM
