Navigation & Audio Someone Replaced my H/K Amp
Old Nov 17, 2010 | 08:52 PM
socalaj1's Avatar
socalaj1
Hi All, recently bought an 04 Cooper S and have come to discover that at some point the H/K Amp was replaced with a 4 channel unit from Alpine. I am suffering from awful sound quality. The Amp is only sending out the Left Front Channel at equal volumes to all speakers. I have tried to understand the wiring as best as I could, but am hoping someone has a wiring diagram of what was going into and out of the H/K Amp so I can try and fix the problem.
Any help is greatly appreciated.
Andy
Old Nov 17, 2010 | 10:02 PM
rkw's Avatar
rkw
Are you sure you don't have an amp that was added to a standard stereo? An H/K system isn't easy to modify because most of its components are incompatible with standard aftermarket components. Do your speaker grill covers have "Harman/Kardon" stamped on them?
Old Nov 17, 2010 | 11:23 PM
socalaj1's Avatar
socalaj1
Yep, speakers have Harmon Kardon on the covers. I have not gone as far as removing the amp to find the model number, but it is alpine, 4 channel, and very small, about 4" square and maybe an inch thick.
Old Nov 18, 2010 | 02:50 AM
daflake's Avatar
daflake
It may be 4 Ohm per channel while the speakers are 2. You need to pull the speakers and see if they are actually HK. If they are, you have a few choices to fix this if they didn't butcher the harness too badly.
Old Nov 18, 2010 | 09:01 AM
rkw's Avatar
rkw
A likely scenario is that the original HK amp failed (a fairly common occurrence), and the previous owner attempted to replace it with a standard amp. It would work poorly unless speakers were changed as well.
Old Nov 18, 2010 | 04:08 PM
GBMINI's Avatar
GBMINI
http://www.gbmini.net/downloads/HKconnections.pdf
eliseo1981
Jan 28, 2021 02:45 PM
SunnySideUp
11
Aug 26, 2015 06:42 AM
yashmack
Aug 15, 2015 03:11 PM
Lee-Oh_825
Aug 11, 2015 10:27 PM
CARdiac
Aug 8, 2015 03:30 PM
