Navigation & Audio 05' OEM Head Unit Volume Knob Issues
05' OEM Head Unit Volume **** Issues
In the past several months I have noticed that my volume **** is getting generally stuck when I try to turn down the music. It takes a few turns for it to eventually turn down the volume.
Any ideas?
Thx
cp
Any ideas?
Thx
cp
Do you have a MFSW? If so, does the volume get 'stuck' with that as well? I'd guess a mechanical fault with the HU, the electronics are not 'seeing' the volume **** turn.
Easiest/cheapest solution would probably be to buy a used head unit. Labor charges even to look at it would probably cost more.
Used units for sale on ebay all the time. $70-120 is the usual range depending on build date (your model plays MP3s, the earlier ones do not.) Note: If you want to use the Aux-in feature, make sure the unit was built in 2003 (the early 2002 units did not support Aux-in)
blackie
Oct 2, 2015 07:41 PM
Navigation & Audio Impedance of Stock Under-Seat Speakers
jnrjr79
Navigation/Audio
18
Sep 18, 2015 05:51 AM
Navigation & Audio help identifying a couple wires
yashmack
Aug 15, 2015 03:11 PM
