Suspension advice on 2003 msc spring install in progress
Old Dec 28, 2003 | 12:01 PM
flyboy2160's Avatar
flyboy2160
i'm following randy's spring install how to.
i'm at the point of trying to rotate the front passenger control arm down far enough to get the strut out, but it won't go down far enough. i need at least 2 more inches to get the strut out.
randy's method doesn't call for compressing the spring on the car. if i did this, it looks like i'd have to fully compress the spring to get enough clearance. that doesn't seem right.
has anybody done this on a 2003 or later mcs and can give advice?
thanks,
flyboy2160
Old Dec 28, 2003 | 12:16 PM
cooper44's Avatar
cooper44
you have to compress the springs! especially on the drivers side since the strut is longer for some crazy reason! you should use the ratchet type tie straps. they are thinner than normal spring compressors and are very easy to work with.
Craig
Old Dec 28, 2003 | 02:53 PM
jlm's Avatar
jlm
I think the struts are the same length; it is the movement of the lower control arm that is reduced on the driver's side.
Old Dec 28, 2003 | 03:36 PM
flyboy2160's Avatar
flyboy2160
well, i tried using 2 ratchet straps but couldn't get enough compression before the pawls locked up. i ended up having to cut them off. i guess i'll try a suicide type compressor (i have a scissors type for off car use.)
anybody know exactly what make and model will fit?
thanks again,
flyboy2160
Old Dec 28, 2003 | 04:29 PM
BlueMCS's Avatar
BlueMCS
See my Mini2 reply
sevin
May 2, 2026 06:11 AM
adrchn
Aug 13, 2019 02:11 AM
melscoop
Mar 30, 2016 06:56 PM
squawSkiBum
Oct 2, 2015 09:21 AM
