looking at higher mileaga 1st gen cooper S have questions.
Old Nov 12, 2010 | 01:05 AM
fkong777's Avatar
fkong777
Hi,
Im looking for a 1st gen cooper s as a commuter. at my budget they are higher mileage 1st Gens @ about 80K to 110K miles. I would appreciate an advice. Im pretty hands on and can do a lot of DIY repairs/maintenance
Questions.
-What should I look out for.
-Is there a page to FAQ and DIY's?
-what is this Strut mushroom issues, is there a fix if I find one w it.
-Can I run it another 100k miles without a bunch of failures?
Basically i drive about 25000 miles a year and need a reliable car without a lot of failure. Hoping CooperS can fit this bill.
TIA for any advice ..
Old Nov 12, 2010 | 03:45 AM
wellzy's Avatar
wellzy
My wife has a 2004 with 99000 on it and other than basic maintenance there have been no problems. Mushrooming is an easy fix.
Old Nov 12, 2010 | 07:15 AM
veggivet's Avatar
veggivet
The best source of information on buying a used first generation can be found at www.motoringfile.com just below the ads in the upper right hand corner.
Old Nov 12, 2010 | 07:18 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Control arm bushings wear out
P/S lines leak
Oil pan gaskets leak
Pass side motor mounts fail
Clutch feel good?
Upper strut mounts broken?
These are the first things I would check cause they are the most common.
Old Nov 12, 2010 | 07:24 AM
buzzsaw's Avatar
buzzsaw
Here's a link with a list of questions to ask. Good luck.
Old Nov 12, 2010 | 07:28 AM
veggivet's Avatar
veggivet
P/S lines leak
Clutch feel good?
Don't forget the door sill rust issue.
Old Nov 12, 2010 | 08:09 AM
LadyGodiva's Avatar
LadyGodiva
Good luck with your search for the perfect MINI!
Old Nov 13, 2010 | 09:31 PM
BensMini's Avatar
BensMini
Good luck in your search, anytime you buy a used car with 100K on the clock you have to expect some repairs may be needed. Choose carefully and you can find a good one.
andrewjg1994
Jan 29, 2021 07:45 PM
maestro39
Oct 27, 2015 02:38 PM
FrostyFox
Aug 12, 2015 02:33 PM
vballkid77
Cooper (non S)
Aug 10, 2015 04:44 PM
jrezzo
Aug 9, 2015 10:32 PM
