R50/53 Weird light not in manual
Old Oct 28, 2010 | 09:27 PM
scarletswalk's Avatar
scarletswalk
Hi everyone,
I was driving my little Zabimaru down the interstate and this light came on (not the seatbelt sign. I've seen that one a time or two). I can't find it in the manual (I literally READ the manual, again, cover to cover), and I need to know what it means. My "oil change" miles are down to about 3500 (but they recommend that I change the oil every 15k. I don't think so). My guesses are as follows: I need to check my brakes; I need to check my belts; my antifreeze is too low; My car is part of the Dharma Initiative. Anyway, can someone please tell me what this means, and what I need to do to get it taken care of?
Thanks in advance.
Old Oct 28, 2010 | 10:01 PM
ericfreeman's Avatar
ericfreeman
Is that the brake pad wear indicator? I don't have my manual with me at the moment but the icon looks like a brake symbol.
Eric
Old Oct 28, 2010 | 10:46 PM
slapshot591's Avatar
slapshot591
brake wear sensor indeed. mine just went off and my back pads are toasted.
if you need further proof, here's the icon that is displayed in VW/Audi if brakes sensors are tripped.
https://wiki.bentleypublishers.com/d.../DSCN4688a.jpg
Old Oct 28, 2010 | 10:48 PM
slapshot591
to fix this, you'll need to figure out which pads are low, either front or rear. you have a sensor on the front left, and the rear right. So, once you figure out which pads are low (you'll have to do some peeking through the wheel to see) and replace those pads, as well as purchase a new sensor, since the sensor you have has been used.
Old Oct 29, 2010 | 12:55 AM
Jazzop's Avatar
Jazzop
FYI, you can probably drive another 1000 miles on stock pads after the sensor trips. I did and when I replaced the pads they still had some life left.
Old Oct 29, 2010 | 05:09 AM
DaveTinNY's Avatar
DaveTinNY
Put your seatbelt on, too.
theblackfalcon
Oct 11, 2015 09:49 AM
I_drive_slow
Aug 18, 2015 10:47 AM
Powershift
Aug 16, 2015 05:14 PM
stellaherself
Aug 14, 2015 05:28 AM
