R50/53 benefits going from 2-spoke mfsw to 3-spoke mfsw
Old Oct 25, 2010 | 11:02 AM
GPToyz's Avatar
GPToyz
I was curious about going to the 3 Spoke MFSW
Is it beefier than the 2-spoke? I assume I get more functions but unless I have nav, bluetooth that's totally irrelevant and if I go with an aftermarket head unit, then MFSW becomes completely irrelevant
Old Oct 25, 2010 | 01:18 PM
rkw's Avatar
rkw
It's beefier only if you get a JCW steering wheel, which is available only in 3-spoke version. The 3-spoke doesn't have a radio Mode button, so functionality actually went down. Otherwise it's a matter of styling preference and some people have felt strongly enough about it to switch one way or the other.
BTW, it is possible to integrate the MFSW with some aftermarket headunits.
Old Oct 25, 2010 | 05:41 PM
GPToyz's Avatar
GPToyz
oh wow!! good knowledge, that takes that mod off the list!
Old Oct 25, 2010 | 06:03 PM
NightFlyR's Avatar
NightFlyR
I have an aftermarket head unit and it works fine with the 2 spoke MFSW, i would really like to get the 3 spoke but i dont know how to do the swap and dont know anyone who has done it that would guide me through it
Old Oct 25, 2010 | 06:06 PM
GPToyz's Avatar
GPToyz
what kind of head unit did you drop in there?
how did you convert the factory harness to your aftermarket harness? adapter?
did the steering wheel controls just work off the bat or did you have to use a pac swi?
Old Oct 25, 2010 | 06:14 PM
NightFlyR's Avatar
NightFlyR
I have an Alpine unit with an adapter, plug and play no issues at all works great.
Old Oct 25, 2010 | 06:26 PM
rkw's Avatar
rkw
Look here: http://web.mac.com/jonnieoh/My_MINI_...el_How-To.html
The writeup is for a JCW steering wheel, but the procedure is exactly the same for standard 3 spoke.
Old Oct 25, 2010 | 06:34 PM
NightFlyR's Avatar
NightFlyR
Thanks for the information, will have to look to do this as a winter project
Old Oct 25, 2010 | 07:03 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
I dumped the two spoker MFSW for a JCW three spoke...the thicker wheel has a much better feel / grip. But never bothered with the MFSW controls.......
Speed control and stero functions are for Lincoln Continentals....
Old Oct 26, 2010 | 03:29 AM
Professor's Avatar
Professor
the 3 spoke is also a smaller diameter than the 2 spoke. I loved making the switch.
Old Oct 26, 2010 | 10:39 AM
GPToyz's Avatar
GPToyz
so the non JCW as well as the JCW 3 spoke steering wheel are smaller in diameter than the 2 spoke?
Old Oct 26, 2010 | 10:54 AM
Eric_Rowland's Avatar
Eric_Rowland
Do you have the 'thumb bump' 2 spoke? IMO they feel much better than the standard 2 spoke.
Old Oct 26, 2010 | 05:29 PM
K5Cruiser's Avatar
K5Cruiser
I went from the 2 to 3 spoke standard wheel. I noticed the 3 spoke to be a tiny bit smaller in diameter. I installed the MFSW controls and it was all plug and play. It's a straight forward easy mod that makes the interior look a bit more up to date.
Old Jan 6, 2011 | 09:36 AM
BMWNTHZST's Avatar
BMWNTHZST
JCW wheel
I'm thinking about buying the jcw wheel too. Where did you buy yours from?
IQRaceworks
53
Jun 28, 2024 07:29 AM
vulkandino
Oct 31, 2015 08:29 PM
Emnotek
Sep 29, 2015 07:37 AM
