Tire Advice Needed - RunFlats are bald, time to get NON run flats (2009 Clubman S)
Old Oct 24, 2010 | 04:55 PM
tattedXB's Avatar
tattedXB
So as the subject says - i'm going to be getting NON run-flats (finally) on my cooper clubman s after about 22k miles or so. I've got the stock 16 rims on now with run-flats - 195,55,16 i THINK?
At any rate, what are people going with 16" wise for NON run flats? Are you finding the best is to stick with the stock tire size, or is there a better tire size with a better ride/better LOOKS that doesnt effect mpg too much.
I want something that LOOKS great, but also rides great and won't go flat if I hit a pot hole
Thanks!
Tire N00b Jeff
Old Oct 24, 2010 | 05:17 PM
Eric_Rowland's Avatar
Eric_Rowland
There are literally hundreds of threads on this, with many opinions. To get an informed opinion, you need to add a few parameters to your request.
Shorthand:
Not many tires in 195/55-16. Your selection goes up drastically if you go to 205/50 or 205/55
You're in SoCal, so summer tires would work unless you go to/near the snow, where you'd want all-seasons. Which is it?
Budget - round and rubber for $50, or only the best for $200?
Old Oct 24, 2010 | 05:37 PM
tattedXB's Avatar
tattedXB
Yeah I know - I saw a few of the other threads but didnt want to hijack them - summer tires are fine for me - is there a big diff between 205/50 205/55?
Old Oct 24, 2010 | 06:06 PM
Eric_Rowland
Not a big difference.
205/50 will tend to give a bit better handling, a bit less (actual) mileage (1.5% smaller)
205/50 will tend to give a bit softer ride, a bit more (actual) mileage (1.8% larger)
Old Oct 25, 2010 | 12:08 AM
tattedXB's Avatar
tattedXB
Much of a difference on looks? Which gives LESS wheel gap? heh
WarEagle
R55 :: Clubman Talk (2008+)
May 3, 2019 03:00 AM
Sexual Chocolate
Mar 31, 2019 08:02 PM
Svejk
Feb 24, 2019 12:18 PM
jbruns29
Aug 14, 2015 01:46 PM
