R50/53 Acceleration problem with 04' MCS
Problem started a few months ago and wasn't a large issue now this problem is constant all the time.
Heres the run down.
Its a 2004 MCS with a Mini Madness intake and 15% pulley with 70k miles. Problem was not present after installing the intake/pulley but 3 years after.
Accelerating in any gear or load.
Vehicle starts to pick up then a massive loss of power (like if you fully lifted off the gas).
Then BAM power comes back on very harsh.
All during constant throttle input.
Now one thing I did find was cruising around 60mph up a hill at constant throttle the same problem would happen but on a smaller level about every 2 seconds and I could do this for as long as possible.
Idle is perfect, you can free rev it and revs to red line just fine.
Thanks for the help,
Dan
Heres the run down.
Dan
No faults are stored in the DME. Also I know if these cars run lean or rich it will set a CEL.
I have not don't a battery reset. I would be very sad to see this being fixed by doing one of those two things.
Marco Guardado
Sep 15, 2015 01:22 AM
