16x8 +0 offset fit on rear of an r56??
Old Oct 23, 2010 | 12:37 AM
RS6hore's Avatar
RS6hore
Hey everyone .. I'm looking at some wheels for the mini , the fronts are 16x7.5 + 38 offset which I know will clear and fit perfect... But for the back it's a 16x8 +0, does anyone know if they will clear calipers and not look ridiluously out of the fender?
Old Oct 23, 2010 | 06:56 AM
Alex@tirerack's Avatar
Alex@tirerack
This is Rally's territory, hopefully he'll pop in soon on this one! Its hard to know about caliuper clearance without knowing about the wheel's spoke design profile.
Alex
Old Oct 23, 2010 | 10:27 AM
Creeve's Avatar
Creeve
No problem with caliper clearance, they will poke 35mm out of the fender though
Old Oct 23, 2010 | 11:14 AM
RS6hore's Avatar
RS6hore
Will that be able to be pulled off with a strechted 195 or 205??
Old Oct 23, 2010 | 11:32 AM
Creeve's Avatar
Creeve
Not IMO
Old Oct 23, 2010 | 01:51 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
It's likely you will. Take it to a good shop that does hellaflush wheels.
see
http://forums.club4ag.com/zerothread?id=53302
For example this is 205mm wide tires on an 8" wide rim
The rear 16x8 will stick out quite a bit.
Some negative camber will help the reduce the difference on the upper edge of the tire from the wheel arch. Adjustable lower control arms will help.
Realize that excessive rear negative camber will increase tendency to understeer so don't turn corners too fast. Tire wear on the inside edges of the rear tires will be higher.
Old Oct 23, 2010 | 02:18 PM
Creeve's Avatar
Creeve
I have to disagree
these are 16x8 et20 up front
et0 will poke almost a full inch more.
even with -3 degrees of camber the will not fit
Old Oct 23, 2010 | 04:14 PM
minihune's Avatar
minihune
Originally Posted by Creeve
I have to disagree
Depends on your idea of "fits".
Yes, severe offset and very wide on the road surface with very large slant inward to "sort of" fit.
severe negative camber
Another option is to go with tires that are much shorter than stock which will give enough clearance to not hit the wheel arches and yes it will stick out.
Never mind the negative camber.
I'm sure this owner thinks his wheels fit fine.
Old Oct 23, 2010 | 04:54 PM
Creeve's Avatar
Creeve
Yes but the OP defined his idea of fitting as "not look ridiluously out of the fender". So wheels that extend 35mm past the fender won't "fit" for him.
Old Oct 23, 2010 | 05:48 PM
RS6hore's Avatar
RS6hore
Yea those wheels aren't gonna work... I've been also looking at these esm 009r wheels that are 16x8 with both +30 and + 20 offsets? You think I can make the +30 offset work all around??
http://www.esmwheels.com/main/produc...sjs5d4n9cgddo2
Old Oct 23, 2010 | 07:26 PM
minihune's Avatar
minihune
OK, +0 offset is extreme for the MINI. Scratch that.
+30mm offset and 16x8 it will still stick out a little more than a 1/2"
Old Oct 30, 2010 | 04:58 AM
Cudda_Kine's Avatar
Cudda_Kine
You can pretty much fit Any rim on there. As long as "it's" over 15". I have 15's and they clear the brake caliper. And i put spacers a while ago
Just Keep in Mind. When I finally get Stance GR+ Coilovers. "It" will look much better^^^
Old Oct 30, 2010 | 05:03 AM
Cudda_Kine's Avatar
Cudda_Kine
R56. Actually now I'm not sure since my car is R50. The Brakes might be different
Old Oct 30, 2010 | 07:36 AM
Creeve's Avatar
Creeve
I don't think you really answered the OP's question.
Old Oct 30, 2010 | 09:59 AM
Cudda_Kine's Avatar
Cudda_Kine
I answered 1 of his two questions. Brake Clearance
Old Oct 30, 2010 | 10:07 AM
Creeve's Avatar
Creeve
Lol yea. Just so you know most R56's require 16" wheels not 15" to clear the calipers.
Old Oct 30, 2010 | 11:37 AM
Cudda_Kine's Avatar
Cudda_Kine
(lol). I'll keep that in mind. Thanks
Old Jul 11, 2011 | 08:59 AM
Minibeagle's Avatar
Minibeagle
Imma highjacking this thread!!
What kind of offset should I look for if I want to go to 16x8 on my R53 MCS with OEM brakes?
Old Jul 12, 2011 | 11:28 AM
Creeve's Avatar
Creeve
between 35 and 25 is optimal IMO
Old Nov 9, 2012 | 12:13 PM
Boosted_Mini's Avatar
Boosted_Mini
Just to bump you can run a 15x8 on an R56 with the S brakes.
SosoMINI
Nov 22, 2015 03:17 PM
Mini'mon
Aug 16, 2015 04:15 PM
Aug 12, 2015 01:24 PM
