R56 215/45-17 Fitment question.
After 30.000 miles in my 2009 mini cooper S tires need to go (stock 205/45-17 RF). I want to replace them with a set of non run flat 215/45-17 would they fit without any rubbing or any sort of mod to the vehicle?
Thanks for the help
Andy
Thanks for the help
Andy
Andy - Why do you want to move from 205/45-17 to 215/45-17? Is it cost, availability, or asthetics?
It's been a while, but from memory, the 215's should be a slightly wider (118.25 mm versus 112.75 mm or approx. 1/4") and slightly taller sidewalls (48.375 mm verusus 46.125 mmr or approx. 1/16").
Just curious - Corey
215/45/17's
No rubbing at all
better ride quality
look much better
*****Fill the wheel well much better*****
********Nice & wide ********
And like Mini Dave say's "Speed-o-meter is a little more accurate.
better ride quality
look much better
I went from the OEM 17" runflats to non-runflat 215/45 17 Hankooks. The ride is a lot more comfortable. The major downside of the wider tires is TRAMLINING e.g. it takes more effort to steer the car, which makes the car feel noticeably less nimble. I wish I had known this beforehand. I will go back to 204/45 17 on my next set of summer tires.
Mine went away
On one road here I had the problem when I first put my tires on but now with over 2,500 miles on them the tramlining is 90% gone. I only had the tramlining on one short stretch of I-95 going north because of the stupid grooves in the roadway.
I just got back from a 2,108 mile vacation trip and never had any problems except for a couple of places with the deep grooves cut into the highway. I'm sure other people in other cars have the same problem.
I found that even though it feels crappy you can actually take your hands off of the steering wheel and the car still goes in a streight line. I just don't let it bother me at all. My Motorcycles always did the same thing, Especially on grated bridges.
When I think back, My Dunlap runflats did the same thing on grooved highways. I'm not about to give up my Michelin's because they are so quiete and ride so good a little tramlining every once in a while does not bother me.
Grizld700
Dec 30, 2015 10:47 AM
