Suspension need to replace ball joints, what else?
Old Oct 16, 2010 | 12:49 PM
ryan319's Avatar
ryan319
i took my 05 MCS for safety inspection today and i need new ball joints (thanks PA potholes!). i assume they meant the outers but if i'm doing it, i might as well do both inner and outer. i'm thinking that i should also replace the control arm and sway bar bushings.
i'll probably drop the subframe so what else should i do while i have it out? tie rods? endlinks? struts? the previous owner put on adjustable endlinks, lowering springs, sway bars, and a strut bar but i'm not sure how many miles are on the endlinks. the car has 55K on it and i don't want to work on the suspension again for a while so i want to do it all now. i might switch back to the stock springs too because the springs on it ride rough.
finally, who's the best vendor to get this stuff from? any brands in particular that i should use?
thanks
Old Oct 18, 2010 | 02:40 AM
Bug Magnet's Avatar
Bug Magnet
same here
I'm looking at the same list of front suspension repairs, so would also be interested in the group's recommendations.
-BM-
Old Oct 19, 2010 | 09:10 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Check out our bushing/ball joint Kit here
The only other thing I'd suggest replacing is the Front swaybar bushings. You can use either Powerflex front swaybar bushings or the OEM front swaybar bushings. Go OEM if you want to save some $$.
Old Oct 20, 2010 | 02:43 AM
vodka's Avatar
vodka
Hi, sorry to hijack the thread... what are the symptom for bad ball joints? beside physically check it. Thank you
Old Oct 20, 2010 | 05:42 AM
WayMotorWorks
Vendor
Alot of times they'll pop or make clunk sounds.
Old Oct 20, 2010 | 09:00 PM
Ammi's Avatar
Ammi
when they pop, is the car still drivable?
Old Oct 20, 2010 | 09:19 PM
WayMotorWorks
Vendor
Yes they usually just make noise, haven't seen them come apart.
Old Oct 21, 2010 | 11:10 AM
jayxx83's Avatar
jayxx83
And the car will follow ruts etc. Replaced my ball joints both inner and outer and it rides so smooth now and the steering is super precise. You may as well do your tie rods as well as doing it all at once will tighten it all up.
Old Oct 23, 2010 | 12:52 AM
vodka's Avatar
vodka
Is it easy to diy replace the inner & outer ball joint? Any how to? Thanks alot
maestro39
Oct 27, 2015 02:38 PM
Beau B
12
Aug 24, 2015 01:50 PM
BennyF
17
Aug 13, 2015 06:29 AM
minipopkart
Aug 13, 2015 05:22 AM
BlimeyCabrio
General Mini related Ads
Aug 12, 2015 06:04 AM
