Fuel issues
Old Oct 6, 2010 | 02:58 PM
Rabidfox's Avatar
Rabidfox
Fuel issues
Very odd...nothings changed mod wise in roughly 1200mi but recently my mileage has dropped dramatically.
I went from a 23mpg avg/tank to 19 (real calculations not scan gauge stuff...23mpg avg based on 8tanks of gas). Scangauge shows a drop from 54 to 29 (50mph 6th gear cruise control same road) real time mpg and from 32 to 21 avg (same route same habits all that jazz). It's my to and from work routine so Its pretty consistent in route, speeds, habits ect
Today it got worse. I'm at a 1/2 tank and the only thing that's changed is the weather (10deg). Scangauge reports 14mpg avg over my route and my 50/6/cc test was 16
I've checked tire pressures all that jazz. It really confuses me because performance hasn't been effected. It starts right up and runs strong. I have noticed on occasion it idles rough but nothing consistent.
Thoughts comments ect? It's semi-heavily mod'd so I don't expect aceptional mpg but seeing it drop like this concerns me. I'm leaning tword fuel filter possibly pump (102k) but I'd think it'd fall on it's face up top. When Jan tuned it over 1200mi ago it ran lean on the dyno and he mentioned pump/filter.
Old Oct 6, 2010 | 04:23 PM
Some Guy's Avatar
Some Guy
I was gonna say maybe your on winter gas now but you are in florida.
Old Oct 6, 2010 | 04:35 PM
Rabidfox's Avatar
Rabidfox
I saw one of gray-raven's posts talkin bout winter gas and I was like WTF is that
Our winter generally consists of 3 days of sub 50* weather and about 3mo of people walkin around in parkas when is 75 out
I had a friend scan it (BMW tool not scangauge to avoid confusion) and among some unrelated airbag garbage there was a CAN bus error at 66k. I didn't own it till 96k and I have no idea what that means but he mentioned that it couldn't clear itself. He also said something about my rear o2 sensor needing to be turned off because I'm catless. Being from the land of k-jet and 80s gray market cars I have no idea WTF that means either
Old Oct 6, 2010 | 07:51 PM
OCKOLBY's Avatar
OCKOLBY
My 04 MCS is getting pretty bad MPG...roughly 19. I have 92K miles. No performance issues other than the occasional idle issue. I' certain we both need to replace the fuel filter AND O2 sensor. You wanna spend the money first and tell me how it works? hahaha
Old Oct 7, 2010 | 05:04 AM
Rabidfox's Avatar
Rabidfox
Well I've got the fuel filter already so it's going in...just a matter of "was that the problem or am I just ****"
Are there crossover parts? Can I pull injectors and an o2 sensor from a ford for example? I know on my old e30 I stole my buddies lighting **** to test and everything worked fine. Is there a wideband I can throw in there?
I'll search for PNs shortly but I think o2 makes sense so I'll probably pick a couple up and do em
Old Oct 7, 2010 | 05:59 AM
Speedwing's Avatar
Speedwing
O2 sensors covered 10 years or 100K on 2004-2006 MINIs per MINI USA due to faults with them. May or may not set codes as failing.
Why purchase them when they are covered??????
Old Oct 7, 2010 | 06:04 AM
Rabidfox's Avatar
Rabidfox
By your statement they arent covered for me...'02 and 102k. I'm not worried about spending the money I'm worried about chasing this problem.
I'm gettin a code for the rear one (00420 iirc) but I'm catless so that's "normal" and its had the code since before I bought it.
Old Oct 7, 2010 | 06:12 AM
Rabidfox's Avatar
Rabidfox
I'm trying to get all the little **** on the mini fixed/replaced/worked out whatever so it can be a bullet-proof "DD" for a few months while I work on my merc. I'm replacing the motor and painting the engine bay/replacing a bunch of little **** I can only do with the motor out so I can't afford to have the mini break while my 2nd car is down
Old Oct 9, 2010 | 02:32 PM
Rabidfox's Avatar
Rabidfox
Buellar...Buellar....
Anyone confirm or deny o2 sensor involvement or am I gonna have to chase this issue for a couple weekends and "forget" to help my community and post my findings?
Old Oct 9, 2010 | 05:18 PM
OCKOLBY's Avatar
OCKOLBY
No no findings...but I'll kick ya in the ***** for being a douche. Just because people don't post up write away doesn't mean they have forgotten...we do have lives outside of our MINI.
Thanks for the question though....come again!
Old Oct 10, 2010 | 07:48 AM
Rabidfox's Avatar
Rabidfox
Come on down
Sorry I figured it was a stupid question and people would know it off hand. I'll refrain from asking semi-technical questions since they seem to confuse you
Nice to see someone round this forum has a pair though
Old Dec 23, 2010 | 11:21 AM
uconnhuskiesfans's Avatar
uconnhuskiesfans
where is the fuel filter on justa ('04)
Old Dec 23, 2010 | 06:25 PM
ZippyNH's Avatar
ZippyNH
I think it is the same as the S...it is in the fuel tank, under the rear seat with the fuel pump.
Check real-oem or penske parts for diagrams/schematics to be sure!!
Old Dec 23, 2010 | 07:49 PM
uconnhuskiesfans
well, if thats the case, that doesnt sound like a do it yourself change...anyone?
Old Feb 4, 2011 | 10:02 AM
dthurst's Avatar
dthurst
I changed my fuel filter out myself. I used this link as a reference:
https://www.northamericanmotoring.co...hange-mcs.html
09R56
Nov 16, 2022 10:49 AM
alex87f
Mar 25, 2017 03:46 PM
silence2-38554
98
Sep 21, 2016 02:52 PM
kpl
Aug 11, 2015 04:52 AM
bc219
Aug 10, 2015 11:22 AM
