R53 drive shafts - HELP
Old Oct 4, 2010 | 11:38 AM
MCSjulz's Avatar
MCSjulz
Hi guys,
In need of new drive shafts so just wanted to ask, is there a difference between the drive shafts in an early 05 R53 and a late 05 R53 (both manual)?
Reason I ask is from my understanding, the gearbox is different in the later R53s (Hollinger I believe).
Also, in your experience would it be worth while picking up a pair from the wrecker? (provided the CVs are in good shape of course) or am I better off getting new ones?
thanks in advance
-Julz
Old Oct 4, 2010 | 12:09 PM
quikmni's Avatar
quikmni
The part numbers appear to be the same for all R53 years so I suspect no difference. RealOEM shows the whole driveshaft with CV joints as a remanufactured part.
Right P/N: 31607574850 $580
Left P/N: 31607574852 $506
Old Oct 4, 2010 | 12:29 PM
chilimac's Avatar
chilimac
try Way at Waymotorsports for a much better price. Also refrain from buying the Chinese axles that sell for $100 per side. They are horrible and WILL fail, sometimes in three months.
Old Oct 4, 2010 | 02:46 PM
quikmni's Avatar
quikmni
I just looked a Mini Mania and they show two different drive shafts depending on the year up to 07/2004 and then after 07/2004. Here is the link.
http://new.minimania.com/web/item/NMD7638/InvDetail.cfm
Still very expensive.
You can also check penskeparts.com and pelicanparts.com.
Melvinyip
Apr 17, 2020 09:28 AM
Emnotek
Aug 13, 2015 05:47 PM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
