Vaccum leak
Old Sep 26, 2010 | 02:31 PM
topcat1963's Avatar
topcat1963
Vaccum leak
I have a 2003 S with 81.000 on it...only had it for about 5 months...the service engine soon light came on recently...I went to autozone and they scanned it and it gave a vaccum leak code. I did service the K and N air filter recently and put it back on snug...but it seems that shortly thereafter is when I started getting this CELS indication....Anyone have any experience on this?
Old Sep 26, 2010 | 02:37 PM
Martin Brenneke's Avatar
Martin Brenneke
What was the code? It will help in trying to figure out the problem.
Old Sep 26, 2010 | 03:04 PM
topcat1963's Avatar
topcat1963
not sure....girl just told me vaccum leak...should have asked her the exact code...I guess I could get it done again....also, I get a strong gas smell after I get on it pretty hard , never smell it while idleing or under normal diiving( slow to moderate acceleration"
Old Sep 26, 2010 | 03:17 PM
Martin Brenneke
Iwould go back and have them redo and give you the code number. Then people can help with answers to fix problem. You can also google code # and will be able to see what might be causing the problem and then give you soom possible fixes.
Old Sep 26, 2010 | 03:23 PM
HRM's Avatar
HRM
You have to double check your work near the filter and make sure there are no hoses that are not going anywhere.
After that the code will help pinpoint were to look.
Old Sep 26, 2010 | 06:00 PM
topcat1963's Avatar
topcat1963
Went back to advanced and they reran scanner....code given was P0420 and they cleared out code..light out and has not come back on yet......since I just did air filter service,,,tech there said that filter may not have been complietly dry after I reisnstalled...and that some of the oil may have gotten inside and could cause a code...I did reinstall filter right after oiling it and started the car...sounds like a possibility
Old Sep 27, 2010 | 04:07 AM
Fatherdeth's Avatar
Fatherdeth
It's possible. Always let the filter sit for a few hours before reinstalling. This will give the oil ample time to fully absorb into the cotton fiber.
ian260
Mar 29, 2017 06:08 AM
Cruzer214
Oct 11, 2015 07:45 AM
Oct 1, 2015 12:13 PM
JAB 67
Sep 29, 2015 01:34 PM
donniedarko
Sep 29, 2015 01:16 PM
