P/S pump fan protector-does it really work?
Old Sep 19, 2010 | 04:04 PM
Audi refugee's Avatar
Audi refugee
I have an '04 R53 with approx' 107 km (65 miles?). It's still on its original p/s pump with no issues. I'd like to prolong its life further and am considering investing in the metal pump fan protector sold buy Outmotoring:
http://www.outmotoring.com/mini-coop...protector.html
Does it really work and prevent failures? Has anyone on here experienced a p/s pump failure while equipped with one of these?
Thanks.
Old Sep 19, 2010 | 04:46 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Originally Posted by Audi refugee
I have an '04 R53 with approx' 107 km (65 miles?). It's still on its original p/s pump with no issues. I'd like to prolong its life further and am considering investing in the metal pump fan protector sold buy Outmotoring:... Has anyone on here experienced a p/s pump failure while equipped with one of these?
This is a simple shield to prevent anything from getting in the fan. It clearly can't hurt. But if you want to prolong the fan, the Power Steering Fan Duct & Panel is the way to go. It says that it is for automatics only but there may be one for the 6-speed too if you ask.
Rich
Old Sep 19, 2010 | 04:59 PM
kazlot's Avatar
kazlot
Rich
The shield is not perfect, the fan and duct panel is much better.
I just had one installed on my car, a 6-speed, because it's cheap insurance.
Hope this helps...
Old Sep 19, 2010 | 06:38 PM
Rich.Wolfson
So we know it fits our 6-speed Minis as well.
Rich
Old Sep 19, 2010 | 07:07 PM
Crashton's Avatar
Crashton
Yes that screen will keep trash out of the fan. I know several folks using them. I think without a screen on there it is only a matter of time until some trash finds its way into the fan.
Old Sep 19, 2010 | 07:54 PM
ED955S's Avatar
ED955S
I checked the fan and electrical wiring conditions every oil change: clean and moving freely, after reading fan malfunction reports that led to fires due to overheating PS pump. I will also do a replacement every 35K.
Old Sep 19, 2010 | 09:10 PM
ZippyNH's Avatar
ZippyNH
I have the duct kit..manual too...
It keeps the grit out of the fan too...so it saves it from both the bigstuff and the dust crap that tears up the bearings. The duct kit, IMO, is the way to go...cheap, oem....what could be better?!
The shield with holes in it...that idea was incorporated into later mini fans...
Early fans lacked a grill, and rocks or plastic bags would jam them...the shield will accomplish the same thing as the factory grill..just stronger...but the sand/grit is still an issue. The duct does tons more to protect it.
Old Sep 20, 2010 | 08:05 AM
apexer's Avatar
apexer
I have the same P/S fan shield on my 04 MCS and have had no problems. Installation is easy.
Old Sep 20, 2010 | 08:56 AM
BlimeyCabrio's Avatar
BlimeyCabrio
The OEM duct kit and periodic cleaning made my fan last 75K miles before it seized and had to be replaced :-)
So even with the duct kit, these things probably won't last forever.
Old Sep 20, 2010 | 09:20 AM
xsmini's Avatar
xsmini
I don"t have any protector on my fan. I do check it every now and then and make sure its spinning freely. This week my car will turn 240,000 miles and the fan has never been a problem, the ps pump went out about 5k miles ago, but had nothing to do with the fan, it was just old.
Personally I think the guards are a waste of time if you check the fan periodically, but if it brings piece of mind than go for it.
Nik
Old Sep 20, 2010 | 12:50 PM
wrh3's Avatar
wrh3
OEM Duct Kit
I have it installed on my manual trans car as well.....
Old Sep 20, 2010 | 07:08 PM
CORNERS's Avatar
CORNERS
How does the duct work? It moves the fan up higher? When I look under my car now (2004 Cooper S) I see the fan is down there just a few inches off the ground.
Old Sep 21, 2010 | 04:17 AM
haji3's Avatar
haji3
i think I have a total of about 200k on all my mini's put together. In my experience, you will know when the fan need replacing, it GROWLS at you! Simple replacement, if you are not having any trouble with the ps cutting out I wouldn't sweat it.
Old Sep 21, 2010 | 07:45 AM
JWA's Avatar
JWA
Does anyone have the part number for this handy? I'll be placing an OEM order here shortly.
Old Sep 21, 2010 | 08:10 AM
JWA's Avatar
JWA
Never mind - I found them, along with a nice writeup: http://www.billswebspace.com/MiniR53PSPFanDuctDIY.htm
Old Sep 21, 2010 | 08:16 AM
JWA's Avatar
JWA
And the listing on RealOEM for any one else looking for them: http://www.realoem.com/bmw/showparts...51&fg=75&hl=10
Old Sep 21, 2010 | 04:09 PM
Rich.Wolfson
So looking at this we can just get the Air Channel and fasteners and cut a hole in the panel and put a screen between the two and we're good to go?
Hummmmmmm.
Rich
Old Sep 21, 2010 | 05:13 PM
JWA's Avatar
JWA
Hummmmmmm.
Rich
Looks like it to me, but I figured that for $40-some bucks it wasn't worth the hassle.
Old Oct 13, 2010 | 10:29 AM
works4me19's Avatar
works4me19
Where do I get the clips for OEM duct kit?
Question on the OEM duct kit on a 6 speed - my MINI dealer is having trouble sourcing the clips. They say it won't use the standard clips. Any suggestions?
I get them to buy the OEM kit that says it's for an automatic, right?
I'm on fan #6 and this is a royal pain.
Old Oct 13, 2010 | 10:34 AM
JWA's Avatar
JWA
Everything will mount right up on a 6-speed - except for the two bolts that mount the duct to the fan housing. the duct comes with two quarter-turn fasteners, but the manual cars don't have the matching holes with the 1/4 turn clips. I just drilled to pilot holes and used two self-tapping screws, which was the recommendation from the lead tech at my dealer.
Sixth fan? Ouch. My fan was pretty loaded up with salt dust, which I would think helps to explain why someone in California can get 240K on theirs but someone in BC gets much less.
Old Oct 13, 2010 | 12:52 PM
wrh3's Avatar
wrh3
I think it depends on manufacture date- I have a 12/04 build '05 MCS and my fan had the holes and I was able to install the clips. I originally installed it using screws but for oil change removal the OE fasteners work better. Part numbers and pics here:
Old Oct 13, 2010 | 01:12 PM
JWA's Avatar
JWA
Oh - your site is where I found the part numbers when I placed my order. Lots of informative stuff there - thanks!
My build date is 12/04 too, but I didn't have the holes. Must have just missed the changeover.
Cereall
Sep 5, 2019 06:05 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
David.R53
Sep 1, 2015 06:51 PM
minipopkart
Aug 13, 2015 05:22 AM
bc219
Aug 10, 2015 11:22 AM
