Drivetrain o2 sensor bung
Old Sep 15, 2010 | 10:17 AM
freeskier's Avatar
freeskier
o2 sensor bung
i need to install a post cat o2 sensor on a custom exhaust with no bung, where can i pick up a threded ring to weld on? thanks
Old Sep 16, 2010 | 04:26 AM
fishead # 1's Avatar
fishead # 1
bung
Autometer & a few of the other gauge mfgs (Innovate) offer them as an accessory to their afr gauges. Both bolt on & weld on. If you get in a pinch the bolt on tho far more $$ CAN be cut / ground & welded which IS the RIGHT way (welded). Just make sure to position it so ANY fluids (moisture/fuel) will "drip" off the end of the O2 (tip angled down). OBEY
Old Sep 16, 2010 | 11:00 AM
freeskier's Avatar
freeskier
yea, im gonna angle the sensor down ish. ill check jegs and autometer now, thanks
Old Sep 16, 2010 | 11:31 AM
freeskier's Avatar
freeskier
found the bung on jegs, they have a huge selection, thanks
shorenetworks
Nov 4, 2019 06:18 PM
CRC
Dec 26, 2015 11:30 AM
sempaipaul
Sep 18, 2015 03:05 PM
Doc Pain
Sep 15, 2015 11:31 PM
Sep 14, 2015 12:48 PM
