Autometer & a few of the other gauge mfgs (Innovate) offer them as an accessory to their afr gauges. Both bolt on & weld on. If you get in a pinch the bolt on tho far more $$ CAN be cut / ground & welded which IS the RIGHT way (welded). Just make sure to position it so ANY fluids (moisture/fuel) will "drip" off the end of the O2 (tip angled down). OBEY
