Will These Fit 2009 Clubman S?
Old Sep 10, 2010 | 05:09 AM
jeffgrice's Avatar
jeffgrice
Hi,
Been searching for winter set of tires and wheels for my 2009 clubman S.
Will these fit? Specifically I understand need certain wheels to clear the S brakes?
https://www.northamericanmotoring.co...?product=13395
Thanks.
Jeff
Old Sep 10, 2010 | 11:15 AM
dwebber18's Avatar
dwebber18
I think the 16" wheels will fit just fine, its the 15" wheels that have the problem I believe. But check the stud size, if I remember they changed to 14x1.25 in 2007 and that's different than previous models. I could be wrong, as I don't remember 100% hopefully someone who remembers right will chime in.
Old Sep 10, 2010 | 02:12 PM
jeffgrice's Avatar
jeffgrice
Thanks. The ad says 14 x 100. So I guess they won't fit.
Can someone point me to the specs for the wheels on my 2009 clubman S so I know what to be looking for?
Thanks!!!
Jeff
Old Sep 10, 2010 | 03:09 PM
kazlot's Avatar
kazlot
Originally Posted by jeffgrice
Hi,
Thanks.
Jeff
The wheels you are considering are the R-103 Blaster, 16x6.5, and yes, they will fit.
The 2009 and older OEM 16 inch wheels that fit your Clubman S are: R-94 Bridge-Spoke, R-102 S-Winder, R-103 Blaster.
The new 2011 OEM 16 inch wheels, shown on the MINI configurator, will of course fit.
The TPMS system was changed in 2010 and forward.
Hope this helps...
Old Sep 11, 2010 | 03:40 AM
jeffgrice's Avatar
jeffgrice
Hi,
Another question.
Please refer to this ad: http://cgi.ebay.com/ebaymotors/16-Wh...ht_4775wt_1165
And specifically this:
"These are original equipment Toyota wheels, not aftermarket wheels. While these are original equipment from a Toyota, all the dimensions are the same as for the cars listed above except for the hub size. These wheels have been modified by increasing the center bore size (by only 2 mm) to fit the vehicles listed here. This is done in a machine shop to very high tolerances and does not affect the strength of the wheel, nor the look of the wheel. These wheels remain hubcentric for all the vehicles listed. You will not need hub rings as you would for aftermarket wheels. We have been doing this modification on various wheels since 2000 and have never had a problem."
Should I be concerned?
Will these fit a clubman S 2009?
Wheel dimensions: 16" x 6.0"
Offset: 45mm
Bolt pattern: 4x100 mm
Thanks!
Jeff
Old Sep 12, 2010 | 07:14 AM
slinger688's Avatar
slinger688
Hi,
Another question.
Offset: 45mm
Thanks!
Jeff
I personally would not get machine shop modified wheels. How would they know it did not change the integrity of the wheel?
Also 16x6 is a little narrow, depending on the width of the tires you get.
WarEagle
R55 :: Clubman Talk (2008+)
May 3, 2019 03:00 AM
Sexual Chocolate
Mar 31, 2019 08:02 PM
jbruns29
Aug 14, 2015 01:46 PM
JPMM
Aug 13, 2015 12:01 PM
Aug 12, 2015 01:24 PM
