Seafoam video 90K miles
Old Sep 6, 2010 | 09:19 AM
OCKOLBY's Avatar
OCKOLBY
Long time stalker of this webpage, newly registered. It's a 04 with about 90K on her. Just did a full tune up and it wouldn't be complete without a good smoke storm. The last thing I have planned is a new clutch. Found a local retired BMW tech who will do it for $900.
http://www.youtube.com/watch?v=gVgC4k-cgfw
Old Sep 8, 2010 | 05:37 AM
fanta's Avatar
fanta
Any noticeable gains in MPG or throttle response?
Old Sep 8, 2010 | 08:20 AM
OCKOLBY's Avatar
OCKOLBY
Not sure on MPG, but it did have the infamous idle hesitation every so often and now that has gone away. It seems to be a lot smoother overall.
Old Sep 9, 2010 | 01:00 AM
steve20607's Avatar
steve20607
Did you use the aerosol spray or the pour the air intake or PVC tubes?
Old Sep 9, 2010 | 02:44 AM
NightFlyR's Avatar
NightFlyR
I did my second treatment yesterday, car does now seem a bit better off Idle and easier to pull away from a light with the A/C on. Not as much dark smoke on the second go through, and I let it sit for a good hour before i ran it. I poured through the Intake with s smaller hose and it just sucked it right in, very easy to do
Old Sep 12, 2010 | 09:37 AM
OCKOLBY's Avatar
OCKOLBY
hmmmmmm very strange. I now have an intermitant service engine soon. It comes on in the morning and after about 5 ignition cycles (on off on off on off....) which is roughly by about mid-day it turns off. I dont have a scanner and here in CA you cant rent them. Car seems to be running great though?
Old Sep 12, 2010 | 01:24 PM
OCKOLBY's Avatar
OCKOLBY
I'm thinking either O2 sensor or perhaps bad coil packs (small changes in voltage will result in SES right?)
Light is currently off. Probably will come on tomorrow morning.
Old Sep 12, 2010 | 02:29 PM
OCKOLBY's Avatar
OCKOLBY
Well I just drove down to the local auto repair shop and the guy let me use his scanner for free...cool guy! Codes that came up were PO130 O2 sensor bank one sensor 1 and PO301 cylinder 1 misfire.
I think these codes are a direct result of Seafoam. Once I have enough cash Ill replace the O2 sensor and see what happens. I erased the codes for now.
Old Sep 12, 2010 | 02:42 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Originally Posted by OCKOLBY
... think these codes are a direct result of Seafoam. Once I have enough cash Ill replace the O2 sensor and see what happens. I erased the codes for now.
I would wait for a while to see if the O2 code comes back and my bet is that it won't. But if it does, clear it one more time before you change it. Cleaning it is too much work so if you are thinking about that, I would just replace it. But it is not cheap and the general consensus is that the OEM sensor is the way to go rather than a Bosch that the books say will work.
As for the misfire, clearly the Seafoam and no problem at all. I usually do my Seafoam treatment just before I am set to change the plugs.
///Rich
Old Sep 12, 2010 | 02:49 PM
OCKOLBY's Avatar
OCKOLBY
///Rich
Thanks for the reassurance I figured the Seafoam is a direct result of all this and after clearing the codes hopefully it doesnt come back.
Old Sep 15, 2010 | 09:08 PM
OCKOLBY's Avatar
OCKOLBY
Just a quick update. After clearing the codes for a few days now I'm happy to report no SES or any issues at all.
Old Oct 6, 2010 | 03:57 PM
CARdiac's Avatar
CARdiac
How did you get the SF in the engine? I used to pull the vacuum hose off the master cyl on my camaro and suck it in that way... how is it done on the S?
Old Oct 14, 2010 | 01:08 AM
steve20607's Avatar
steve20607
PVC tube left side?
We finally got a chance to pour 1/2 can of Seafoam into the PVC tube that's to your left as you look into the engine bay. It's the one nearby the MINI logo on the engine block.
From the various vid's and information here, it seemed like the "correct tube" to use, but it didn't suck up the Seafoam as expected, instead it sat inside the tube for a couple of minutes or so, sometimes even spitting it out in little squirts. We also put our thumb to cover the open hose thinking it should have sucked it in quicker, but it still just stayed in the tube for a while.
We let it rest for a good 35 minutes then cranked the engine over......no smoke, neither white or black. It did idle slightly with hestiation but went away, no CEL lights either. It runs fine otherwise.
So was the Seafoam used properly? We have almost 73K and first time Seafoamer on the S.
Old Oct 14, 2010 | 03:05 AM
HRM's Avatar
HRM
Steve, it sounds like the pvc tube is not connected to the throttle body, hence, no suction.
You can look under the stock intake tube to see if that is the case. If it looks connected, it may be plugged or otherwise blocked.
iggi
18
Feb 9, 2026 01:00 AM
silence2-38554
98
Sep 21, 2016 02:52 PM
mct
Nov 29, 2015 04:51 PM
minipopkart
Aug 13, 2015 05:22 AM
MIminiclubman
Aug 5, 2015 09:14 PM
