Would wheels on Gen 1 fit Gen 2 w/o spacers?
Old Sep 4, 2010 | 08:04 PM
vettestripes's Avatar
vettestripes
Hi,
From what I've scanned thru forum for past 9 days after owning my first Mini for 10 days, look like wheels on Gen 1 will fit on Gen 2 with some spacers?
When I search wheels for 2010 MCS, they are not showing anything much but when searching for 2004 MCS, there are many.
For example, the Konig Feather was not listed under 2008 MCS but was listed for 2004 MCS.
Thanks so much in advance!
-Mike
Old Sep 4, 2010 | 08:27 PM
5zero4's Avatar
5zero4
As far as I am aware, the offset and lug pattern in exactly the same. The only problem is fitting over the brakes on 2007- cooper s with some of the smaller size rims.
Old Sep 4, 2010 | 08:36 PM
vettestripes
Thanks!
I am doing at least 17" wheels so I don't think it is an issue.
Old Sep 4, 2010 | 08:56 PM
ScottRiqui's Avatar
ScottRiqui
Also, I don't believe that all of the earlier wheels will mount the TPMS sensors (if that's important to you.)
Otherwise, Black56S is correct that the bolt pattern, bolt hole diameter, offset and centerbore diameter are all compatible between 1st and 2nd Gen MINIs.
Old Sep 5, 2010 | 01:17 PM
MINIdave's Avatar
MINIdave
The bolts themselves are different sized - 12mm on 1st gen cars and the very last '06's and 2nd gen cars are 14mm. Some wheel designs won't accomodate the larger bolts.
You would have to add the correct TPMS sensors for 2nd gen cars, but they should fit the wheels. 07-09 TPMS are different than '10.
Old Sep 5, 2010 | 01:31 PM
ran-o-matic's Avatar
ran-o-matic
The bolt size is not a problem on OEM wheels.
Old Sep 5, 2010 | 06:41 PM
vettestripes
Would the 14mm bolts be too big for after market gen1 wheels bolt holes?
I really haven't see bolt hole size issue before. Maybe I haven't seen enough :-)
Old Sep 5, 2010 | 06:46 PM
ScottRiqui's Avatar
ScottRiqui
With aftermarket wheels, all bets are off. The 14 mm bolts wouldn't fit through my Konig Heliums, but I've seen other aftermarket wheels that worked just fine with the larger bolts.
Old Sep 7, 2010 | 11:39 AM
vettestripes
Great to hear this!
Since if the wheels fit '08 MCS then it would fit my '10 MCS.
Thanks!
-Mike
Old Sep 7, 2010 | 09:16 PM
Calz's Avatar
Calz
Have not seen a problem yet
The only wheels that dont fit are 15inch wheels on Cooper S and 15 or 16 inch on JCW with 4 piston. Have not fit too many wheels to R56 JCW but all OEM offsets look like they work in 17 and 18
Mini'mon
Aug 16, 2015 04:15 PM
Emnotek
Aug 13, 2015 05:47 PM
Rennfahrer555
Aug 13, 2015 09:07 AM
