05 MCS:: Clutch pedal sticking
Old Sep 1, 2010 | 12:26 PM
wardfactor's Avatar
wardfactor
i was wondering if someone knows why the clutch pedal would be sticking in the down position? the car shifts fineonce i manually return it to the up position but i know that gettinga new clutch will cost me big. hopefully there is another reason why would be sticking ....help please
Old Sep 1, 2010 | 12:40 PM
ZippyNH's Avatar
ZippyNH
It could be a bad master cylinder/slave....so the clutch MIGHT be OK. It might need to be replaced/bleed...it is hydrolic.
http://www.waymotorworks.com/oem-clu...-cylinder.html
http://www.waymotorworks.com/clutch-...-cylinder.html
Old Sep 1, 2010 | 12:59 PM
wardfactor's Avatar
wardfactor
thanks i'll have some info for the mechanic i'll see if he can check it out. that helps i would have done the clutch replacement and cost me big dollars
Old Sep 1, 2010 | 02:01 PM
ZippyNH's Avatar
ZippyNH
Just be sure to say..."x is the problem, can you fix it" and maybe say..."i have heard some of these cars have issues with the master/slave" ...let the mechanic do his diagnosis......
The place you are going to...is it a mini centric shop?! These cars are kinda quirky, and the learning curve is kinda steep....and it is best to letthe mechanics learn on somebody's else's nickel!! I drive about an hour to my MINI guy....a bit further than the dealer...but the prices are good, service is great, and he does a good job! Do a bit of research, and find a good shop...check with the "local" clubs/members in your area. Where are you located?!
Old Sep 2, 2010 | 05:25 AM
wardfactor's Avatar
wardfactor
i live in rhode island not sure if my guy deals with alot of minis but heard the dealer will charge me an arm and leg. i trust my mechanic if he can't fix it he'll say so. i appreciate your response since i have only had my mini for 2 months i am unfamiliar with the "quirks "
Old Sep 2, 2010 | 12:40 PM
ZippyNH's Avatar
ZippyNH
Lots of folks from RI, VT, and ME and me in NH go to
Greasy’s Garage
143A Hamilton Street
Worcester, MA 01604
He is THE independent shop to go to in the NE. Not a fancy place, but well worth the drive IMO. Been open about 2 years (a few months at his current location), and he maintains 200+ regular MINI's, plus his other customers cars! This is saying lots since he does almost all the MINI stuff himself....it is a small shop, but he is great with scheduling!!
he is also the founder of a MINI centric board like this for the Massachusetts area.....so he is a MINI maniac...he had one till it was totaled...and he is working on getting a "new" gen1 MINI.
Old Sep 2, 2010 | 08:18 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Check the clutch slave cylinder, that's most likely leaking.
thadscottmoore
Sep 25, 2015 10:07 AM
Sep 22, 2015 02:05 PM
leonardogia
Sep 19, 2015 12:25 PM
wildwestrider
Sep 4, 2015 06:25 AM
