2004 Mini Rotor Replacement
Old Aug 31, 2010 | 05:16 PM
Tomahawk_seven's Avatar
Tomahawk_seven
Hello Mini Fans!
I own a 2004 Mini that I will be changing the brakes on soon. (the left rear started to grind grind!)
I will have to replace the rotors on this change.
I am a DIY guy and want to know of any tips that you can share.
Thanks!
Erik
Old Aug 31, 2010 | 05:30 PM
MINI33342's Avatar
MINI33342
Should be a straight forward swap. Only real issue is if the torx bolt is stuck. Then you just need to let it soak with some penetrating oil and try an impact wrench on it.
Old Aug 31, 2010 | 05:34 PM
miniconcarne's Avatar
miniconcarne
Rears can be a pain, here are a few links to help:
https://www.northamericanmotoring.co...beginners.html
https://www.northamericanmotoring.co...ed-advice.html
Old Aug 31, 2010 | 08:44 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Erik
It's pretty simple, just make sure you get some quality rotors, we see problems from cheap autozone/napa rotors all the time.
Toolman
Jan 20, 2016 06:50 AM
Yazon
Tires, Wheels, & Brakes
11
Aug 27, 2015 04:41 PM
nomar116
Aug 10, 2015 11:24 PM
StealthR53
Aug 8, 2015 10:59 AM
