Compatibility of tires of different sizes.Same car.
Old Aug 31, 2010 | 08:47 AM
anthony2010's Avatar
anthony2010
I want to change tires with 155/65 R13 size to 155/70 R13.As I know,the
diameter and width are the same,but the sidewall is slightly higher,so can I
(safely) do that type of change ?
Has anyone experienced changing tires of slightly different sizes with the same car?
Old Aug 31, 2010 | 10:26 AM
hsautocrosser's Avatar
hsautocrosser
The diameter is not the same. 13 is the diameter of the wheel. The tire diameter is larger by 2 times the increase in sidewall height.
Old Aug 31, 2010 | 11:17 AM
hsautocrosser
The sidewalls are going to be in the neighborhood of 3/10ths of an inch taller. And if you have minimum clearance now, you might want to look up the measured section widths of each tire even if they are the same brand.
W0TM8
Dec 19, 2019 07:50 AM
AdrenaliNate
Aug 24, 2015 12:37 PM
kyungmanpark
Aug 23, 2015 07:26 PM
Rennfahrer555
Aug 13, 2015 09:07 AM
Dashdog
Aug 10, 2015 06:17 AM
