Rear Taillights Out
Old Aug 30, 2010 | 10:59 AM
Burn Rubber's Avatar
Burn Rubber
Rear Taillights Out
Any advice on tail lights that could steer me to solving why they are out would be greatly appreciated . The turn signals do work . Possibly I should check the fuse box before removing the tail light covers ?
Old Aug 30, 2010 | 06:21 PM
Fatherdeth's Avatar
Fatherdeth
Check the fuse first. If it's not the fuse, check the bulbs and see if they are burned out. I highly doubt they both went out at the exact same time. If the bulbs and fuse are good, then it's tome to check some wiring. Sometimes the tailights are known to leak. Could have caused a short.
Old Sep 1, 2010 | 04:44 PM
Burn Rubber
Thank you Fatherdeth for the response . I will try to find out where the fuse panels are located and , I hope , to locate the correct fuse for my problem . The turn signals work as well as the break lights and turn signals. when I correct the rear taillight problem, the information I have gained will be posted of all to use.
Thanks, Mike
emulajavi
Dec 24, 2018 09:15 AM
Mini'mon
Aug 26, 2015 01:02 PM
mcoopers81
Aug 19, 2015 01:42 PM
