Drivetrain Instructions for 15% to 17% pulley
Old Aug 30, 2010 | 10:25 AM
Mini SUV's Avatar
Mini SUV
I'm looking for some instructions on upgrading from a 15% to 17% pully. I won't need to remove the tensioner, but don't think I can get the 4 pully bolts out without jacking up the engine a bit. I did the 15% myself and don't think I need to go through all those steps again. Thanks.
Old Aug 30, 2010 | 03:14 PM
jhiggs26's Avatar
jhiggs26
There was enough room to go from a 15% Classic Alta to 17% Alta V2 conversion for me.
Jeremy
Old Sep 1, 2010 | 02:04 PM
Mini SUV's Avatar
Mini SUV
Great! Did you get to it from above from under the car? Looks like a real tight reach to me.
Old Sep 1, 2010 | 05:15 PM
daflake's Avatar
daflake
Just try to get to them without jacking and if you can't have the stuff ready to jack it if needed. You might also remove the well cover on the passenger side to see if you can get up there a little easier. Other than that, it is basically the same as you did it before minus the puller.
Old Sep 1, 2010 | 09:51 PM
jhiggs26's Avatar
jhiggs26
You can get at it from above but I removed the wheel liner to change belts and add a tensioner stop. I'm running a 1360mm belt now instead of the 1365mm-1374mm belts.
Jeremy
Old Sep 1, 2010 | 11:52 PM
user 7082082's Avatar
user 7082082
Old Sep 2, 2010 | 05:19 AM
Mini SUV's Avatar
Mini SUV
Thanks for the good info.... I'm going to tackle it over the long weekend.
pglgp1292
Aug 9, 2017 12:45 PM
vulkandino
Oct 31, 2015 08:29 PM
rt808
Sep 29, 2015 12:30 AM
audio131
Sep 28, 2015 02:21 PM
daviday
Sep 25, 2015 01:31 AM
