Drivetrain Military Time from the ALTA Intake
Old Dec 15, 2003 | 05:32 PM
ukbyoung's Avatar
ukbyoung
I recently put in an ALTA Intake in my MCS and then when I went on a test drive I noticed that the time was in military time. I kinda like it better since I have always used it over standard time, but my question is, is has this happened to anyone else? How do change from one to another?
B
Old Dec 15, 2003 | 05:35 PM
wenzor1's Avatar
wenzor1
disconneting the battery terminal may have reset the clock?
Old Dec 15, 2003 | 05:53 PM
dominicminicoopers's Avatar
dominicminicoopers
Press and hold both buttons simultaneous for a short bit. It'll change from Military to Standard. Haven't a clue as to how you changed it , though...
Old Dec 15, 2003 | 05:55 PM
Ryephile's Avatar
Ryephile
Why would you disconnect the battery to do an intake install?
In any case, just push both clock buttons simultaneously to toggle between AM/PM and Military time.
Enjoy
_________________
Old Dec 15, 2003 | 06:10 PM
macncheese's Avatar
macncheese
All intakes now include a free enlistment. Contact Alta for the branch you've been enlisted in. Good Luck!
Cheese
Old Dec 15, 2003 | 09:56 PM
GRENDEL's Avatar
GRENDEL
In order to put in the Box, you need to disconnect the ECU.
Old Dec 16, 2003 | 01:35 AM
erik808's Avatar
erik808
>>Cheese
===>Hilarious, dude
Old Dec 18, 2003 | 10:58 AM
drnester's Avatar
drnester
I just installed an Alta intake and you don't disconnect the battery terminal, just remove it from the stock box and relocate it to the connector on the new so that wouldn't change the clock. More likely , it was from disconnecting the ecv terminals and then reconnecting them after you put the new box in. I never had any changes in the clock though myself. U were just lucky i guess.....
W0TM8
Dec 19, 2019 07:50 AM
AWOL
Mar 28, 2016 10:51 AM
tr3y003
Oct 22, 2015 10:48 AM
stierzy34
Sep 15, 2015 04:40 PM
jrezzo
Aug 9, 2015 10:32 PM
