help with crankshaft pulley please?
Old Aug 28, 2010 | 07:35 PM
ashleycatt's Avatar
ashleycatt
I am new on here i bought a 06 AB/B MCS about 2 months ago and the crankshaft pulley went bad i was wondering about the super damper by Ati and the Pro SerieS Fluid Filled Harmonic Balancer any suggestions would be supper nice
thanks ashleycatt
This is my broke MINI face
Old Aug 28, 2010 | 08:22 PM
Revolution Mini Works's Avatar
We have a real fluid damper
$285 plus shipping
Old Aug 29, 2010 | 06:46 AM
Mini Mania's Avatar
You have a number of choices for sure:
http://new.minimania.com/web/SUBTYPE..._Inventory.cfm
This new design is a direct replacement for the stock OEM Mini Cooper and Mini Cooper S damper. The heart of this unit is the tried and true “damper within a damper” design that has put ATI ahead of the rest. The outer shell has been machined to allow OEM serpentine belt locations, and includes laser-etched timing marks.
PRW Fluid Dampers are made with an internal steel intertia ring that is surrounded by a high viscosity silicone gel. The internal intertia ring "floats" in the silicone gel to combat the engine harmonics at all RPM ranges. Crankshaft and bearing life is significantly improved and safely increases torque and horsepower.
Old Aug 29, 2010 | 07:47 AM
thanks for the picture Don............
Don is 100% correct.........this is why the PRW damper is better
we use it on all our cars now
Old Aug 30, 2010 | 09:16 PM
slapshot591's Avatar
slapshot591
what are the weights on these bad boys?
Old Nov 11, 2010 | 08:56 PM
AK.JCW's Avatar
AK.JCW
The ATI pulley is either standard or 2% overdrive at Way motor works. Do they make the PRW in a 2% overdrive as well?
Yes I am in the market for one, but the overdrive sounds like a nice boost if you have to replace the pulley anyway. What should I worry about doing an overdrive with a 17% SC pulley?
bahman
Feb 14, 2016 10:29 AM
Debi's Coop S
Oct 3, 2015 08:19 AM
fkrowland
Sep 30, 2015 10:30 AM
audio131
Sep 28, 2015 02:21 PM
daviday
Sep 25, 2015 01:31 AM
