Drivetrain JCW sport brake kit - red caliper paint question
Old Aug 19, 2010 | 10:26 PM
BlueMax's Avatar
BlueMax
Will be installing a new R53 JCW sport brake kit on my 04 MCS tomorrow. Quick question on the red paint used on the calipers, is it resistant to a) brake fluid and b) brake cleaner? Just want to know as a precaution because brake fluid will get onto it during the install and bleed process. Thanks
Old Aug 19, 2010 | 10:53 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
The paint/powdercoat on the JCW calibers is really sturdy. But be safe and try to get as little as possible of brake clean or fluid as possible.
Old Aug 20, 2010 | 06:05 AM
Speedwing's Avatar
Speedwing
Using a piece of tubing over the brake bleed screw to allow fluid flow to a proper container so air will NOT SUCK back in is the old school method .... but works with a "Pumper" in the car.
Using a vacuum bleed system is the modern way of one man brake bleeding...and you should not be spilling a drop.
As said the powdercoat is pretty tough .... but be cautious and clean off any spilled brake fluid immeadiatly.
Bob
Old Aug 23, 2010 | 10:20 PM
BlueMax's Avatar
BlueMax
Thanks for the replys. Installed on Saturday, allmost bedded in. Only bled the fronts using a one-man bleeding kit, minimal spillage which I quickly removed. Kept slight pressure on brake pedal when removing the calipers so no fluid escaped out of the hoses. Very satisfied so far.
minimofo
Factory JCW Talk (2009+)
130
Oct 14, 2016 06:14 AM
dcrna1
Aug 19, 2015 01:30 PM
nomar116
Aug 10, 2015 11:24 PM
