R52 How do I clear the worn Brake Pad light on my 2008 MCSC
Old Aug 19, 2010 | 06:17 AM
JWalls's Avatar
JWalls
I have just replaced the pads on my 2008 MCSC and I need to know how to get the light to go off. Does anyone know?
Old Aug 19, 2010 | 06:45 AM
ScottRiqui's Avatar
ScottRiqui
If the brake wear indicator light came on, that means that the brake wear sensor wore through and should have been replaced when you replaced the pads. You can't reset the warning light until the wear sensor has been replaced.
In the future, if you replace the pads before the sensor actually wears though, you can continue to use the same sensor forever.
Old Aug 19, 2010 | 12:27 PM
Capt_bj's Avatar
Capt_bj
once there is a good sensor in place
turn the key to position #2 - ON
but don't start the car, let it sit for 30 seconds and the light should clear.
(found this lil tidbit buried in the MiniMania part description)
if you don't want to replace the sensor you can trick the system. The sensor works by breaking a wire. The sensor sits in the pad slot and when the pad gets thin enuf the sensor hits the rotor. Eventually the sensor wears down until a wire in the sensor breaks. This open circuit triggers the light. You must close this circuit to clear the lite. You replace the sensor - or you can disect the old sensor, find the wire ends and splice it together. Then just zip-tie the sensor out of the way. Just remember you no longer have a sensor on that axle.
You can NOT simply remove the sensor as that leaves the open circuit.
note there are two sensors - left front and right rear, on the inner pad only.
W0TM8
Dec 19, 2019 07:50 AM
bjcarter2
Aug 31, 2015 04:03 PM
fjork_duf
Tires, Wheels, & Brakes
Aug 16, 2015 04:38 PM
