Airbag Light!!!!
Old Aug 18, 2010 | 11:17 PM
v_diddy's Avatar
v_diddy
Airbag Light!!!!
I bought a 06 mini cooper s that was involved in an accident and the airbags where deployed. I changed the airbags, buckles and reset the srs module. And the airbag light is still on!! The dealer told me i need to reprogram the MRS module i dont know if thats true or is there a way around it? Please Help!!!!
Old Aug 21, 2010 | 03:48 PM
v_diddy's Avatar
v_diddy
Anyone???
Old Aug 21, 2010 | 05:31 PM
krishnika's Avatar
krishnika
I'm no expert, but my airbag light came on too (although no accident). I've done several searches on the forum and the consensus seem to be that only the dealer can reset the light since it's a safety issue. I think if the light is on, the airbags are disabled.
Old Aug 22, 2010 | 08:10 PM
coopspeed's Avatar
coopspeed
Battery cable?
I had the same problem.
If you have a B200 code scanner it will tell you the problem.
Did you replace the battery cable? That was my problem. Not an obvious thing like airbags and seatbelt tensioners.
I got around replacing the cable with a 99 cent resistor, but do what you want to.
Coop
Old Aug 22, 2010 | 08:15 PM
coopspeed's Avatar
coopspeed
B200 will reset and diagnose. I paid $70 for a used one but they can be had for $100 or so new online.
My dealer wanted $180 for a reset. Of course they would have told me that I needed a new battery cable for $393, plus install - figure $1100 out the door.
You decide.
Old Aug 23, 2010 | 03:13 AM
HRM's Avatar
HRM
Airbag lights need to be reset. Some software sold to consumers will reset it, though many won't. Dealer can reset it.
Old Aug 23, 2010 | 11:32 AM
JumpingJackFlash's Avatar
JumpingJackFlash
coopspeed, thanks for the info. I think I will pick one of these up as well.
Here's a couple of links with a price of ~$57:
http://gadgetloversguide.com/57-53-b...an-reset-tool/
http://www.dealextreme.com/details.dx/sku.35188
Old Aug 23, 2010 | 09:48 PM
Calz's Avatar
Calz
If its a new SRS module it needs to be programmed to the I assure you 100%
even if the codes are not present the airbag light will be on until manually turned off with a scan tool
Old Aug 31, 2010 | 10:33 AM
n3nyongmini's Avatar
n3nyongmini
B200 scan tool work with post '03?
Anybody tried using this on a post '03? ( specs say good up to '03 models)
I have an '05 with an airbag light on.
thx
Old Aug 31, 2010 | 10:50 AM
ZippyNH's Avatar
ZippyNH
Peake makes tools that will reset a airbag light....they are round just like their BMW/MINI ODB2 tools. It is important to remember....it will only reset the light...if the faults are all fixed, you are good to go.
http://new.minimania.com/web/Item/NME4020/InvDetail.cfm
The tool can be found for much less...sometimes the airbag only tool version pops up used on the market too!!
In about 2 minutes I found it for 129.00...so priced do vary...but beware...some versions will do the airbag, some do not.
Old Aug 31, 2010 | 10:51 AM
Mr. Steezy's Avatar
Mr. Steezy
thx
I just went ahead and ordered one, I'm 99% sure it will work though, The software tha I use to use for my VW/Audi did the same thing and it worked flawlessly. For 57.00 you can't go wrong, especially if other problems occur down the road. You could also rent it out too to other friends
Old Aug 31, 2010 | 10:54 AM
n3nyongmini
cool. let us know how it works. I run a VAG/COM as well heh heh heh.
Teh
Jun 13, 2018 02:59 PM
trw92a
Aug 26, 2015 01:47 PM
one73ronin
Aug 19, 2015 12:36 PM
quality_sound
Aug 7, 2015 09:36 AM
