AC blows hot and compressor is not turning
Old Aug 14, 2010 | 12:11 PM
tiny s's Avatar
tiny s
Drove to work the other day and ac worked great, drove home and ac blew hot air. Checked and found that the compressor does not spin if ac is on or off. I have a 04 mcs. Any suggestions on a cheap fix or does this mean the compressor needs to be replaced? Thanx
Old Aug 14, 2010 | 12:13 PM
tiny s's Avatar
tiny s
Also did a fuse check under the dash and in the engine compartment and they all seem fine.
Old Aug 14, 2010 | 01:47 PM
dinnertime's Avatar
dinnertime
Had the same problem, make sure your low speed fans work.
My low speed, fan and compressor were bad.
Old Aug 14, 2010 | 01:58 PM
Capt_bj's Avatar
Capt_bj
I had a failure of the clutch in the compressor ...
required a new compressor - sorry
Old Aug 14, 2010 | 04:22 PM
tiny s's Avatar
tiny s
stuff
Where are the low speed fans located?
Old Aug 14, 2010 | 04:55 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Behind the radiator. i don't think the lack of the low speed can cause the A/C clutch to go bad but it does lower efficiency and can lead to complete compressor failure due to higher pressures.
The low speed should come on whenever the A/C is on. If the clutch does not come on it could mean that the Freon is way too low but in most of the cases reported here it is the clutch which cannot be sourced without the entire compressor. For me that was a $1200 repair.
But if the low speed fan is out you should have that repaired at the same time while your Mini is in Service Mode.
Rich
Old Aug 14, 2010 | 04:57 PM
tiny s's Avatar
tiny s
stuff
Are you talking about the radiator fan? If so I know that that has been making a ticking noise for some time but pretty sure its still going.
Old Aug 14, 2010 | 05:09 PM
tiny s's Avatar
tiny s
stuff
Ah, ignore the last message. So the 1 radiator fan (i think theres only 1) has different speeds? Im not to sure it comes on with the ac and being that the ac compressor is not coming on at all now I wouldnt be able to determine that right?
Old Aug 14, 2010 | 08:06 PM
Rich.Wolfson
Yes.
I'm not to sure it comes on with the ac and being that the ac compressor is not coming on at all now I wouldnt be able to determine that right?
Nope. It should come on if the A/C is working or not when you turn the A/C on. But if you leave it idle for 5 minutes it should come on as well. It is quiet unlike the high-speed so you actually have to look to see if it is spinning.
IMO it is a bad design although it was upgraded in 2004 to be a bit better.
Rich
Old Aug 14, 2010 | 08:25 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Most times, the clutch fails after the car has some mileage on it anyways, so most places just replace the whole compressor. But, some cars like Subaru, you can buy a new magnetic clutch from the dealer....unfortunately we are not so lucky.
Our club mechanic has a source for a suitable aftermarket one at about half the price....So far no duds. I'll ask and send ya a PM.
Old Aug 14, 2010 | 08:35 PM
Wetworth's Avatar
Wetworth
I have a bad A/C compressor. I know the dealership wants $1800 to replace; what's a more realistic price?
Old Aug 14, 2010 | 08:42 PM
Rich.Wolfson
It cost me $1200 at a quality independent here in NJ.
Rich
Old Aug 14, 2010 | 09:26 PM
tiny s's Avatar
tiny s
stuff
Wow, I found a compressor between the prices of $160 used to $250-$300 refurbished. I will check the relay but prob need the compressor.
Old Aug 14, 2010 | 09:42 PM
dinnertime's Avatar
dinnertime
I got a re-man for around 300$ and aftermarket fan assembly (mine was toast) for around 200.
I did the repair myself though, but I think the labor time is something like 5 or 6 hours.
W0TM8
Dec 19, 2019 07:50 AM
doug5g
12
Apr 17, 2019 12:44 PM
cub4bearindiana
Jun 30, 2016 06:11 AM
PParker74
R55 :: Clubman Talk (2008+)
Aug 30, 2015 04:20 PM
damncajun
Aug 17, 2015 08:25 PM
