Suspension rear camber change
Old Aug 13, 2010 | 12:20 PM
tvrgeek's Avatar
tvrgeek
rear camber change
I did some rough measurements on the rear links. A quick bit of graph paper says it looks like it is designed to add about three degrees negative with two inches of bump. This is almost exactly canceling the body roll. Really rough measurements.
What it means is we should not need stupid amounts of rear negative camber to get it to behave. Does this match the experience of those of you who track them?
Old Aug 13, 2010 | 12:37 PM
andyroo's Avatar
andyroo
I've been thinking this for a while.....
I only plan to run -1.25 or so on my R53. I bet the -1.5 and more people run is compromising rear grip, especially on stiffer cars.
- drew
Old Aug 13, 2010 | 05:48 PM
veggivet's Avatar
veggivet
Negative 1.5 is probably the most you should run in the back for track purposes. Up front is a different story...
sprp85
Aug 22, 2015 06:16 AM
FLYM1N1
Aug 16, 2015 01:17 PM
Minibeagle
Aug 13, 2015 10:00 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
