Rear Wiper
Old Aug 12, 2010 | 10:22 AM
Wetworth's Avatar
Wetworth
Rear Wiper
Anyone know if it'd be easy to access the rear wiper motor? It wasn't doing a full wipe and the dealership told me I'd need a new motor. However, on the way home I turned it on (it was pointed straight up ) and it seems to work fine, except it's new home position is about 3 inches up wards from where it should be.
Michael
Old Aug 12, 2010 | 11:36 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Not sure why the thing has a new resting position, but you can take the wiper arm off and reposition it on the splines. The plastic cap should pop off and the there is a bolt to take out.
Old Aug 12, 2010 | 11:53 AM
MI MINI S's Avatar
MI MINI S
Be careful removing the rear wiper arm assembly from the motor shaft. The shaft is hollow for the widow sprayer and can be damaged very easily.
Old Aug 12, 2010 | 01:17 PM
Wetworth's Avatar
Wetworth
I don't think that moving the wipers position on the shaft will fix this because when the wiper is turned on it initially moves down wards the distance necessary to reach its original position, then does a full sweep returning to its "new" position. Maybe this is a computer issue?
Michael
Old Aug 13, 2010 | 08:39 AM
Wetworth's Avatar
Wetworth
There doesn’t appear, at least to me, anything on the motor that I can adjust. Anyone have any ideas?
Old Aug 17, 2010 | 04:28 AM
Wetworth's Avatar
Wetworth
If it helps, I can post a vid.
Old Aug 19, 2010 | 12:24 PM
Wetworth's Avatar
Wetworth
Here's a video of the problem:
http://www.youtube.com/watch?v=FKJwNpVbkI0
Old Aug 19, 2010 | 12:43 PM
Capt_bj's Avatar
Capt_bj
just a guess but looks like something shifted inside the motor causing it to loose the index where to stop. Since you can't adjust anything outside .. . I'd learn to live with it unless you want to buy a motor . . .
Old Aug 19, 2010 | 01:09 PM
Wetworth's Avatar
Wetworth
Good thing new motors are cheap I haven't given up yet though.
Old Oct 2, 2010 | 07:21 PM
Wetworth's Avatar
Wetworth
Just wanted to share an update: ran the rear wiper in the rain tonight and noticed that it has fixed itself. Go figure but glad I don't have to pay for it
Old Oct 3, 2010 | 09:13 AM
ACallahan's Avatar
ACallahan
Access to the rear wiper motor not very difficult, did it recently to install my wiper delete. By the way if anyone is looking for a motor complete with wiper blade assembly PM me.
Accessory Products
Aug 25, 2015 10:03 AM
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
