code p1125 and p0638 no start
Old Aug 12, 2010 | 04:49 AM
williambmac's Avatar
williambmac
Hey everyone, I am having a problem with a 2002 mini cooper s. Perhaps someone could help point me in the right direction. I am getting codes p1125 and p0638, now originally when the codes first appeared the vehicle would go into limp mode, but now the vehicle won't even start. I have attempted to clear the codes but the vehicle still won't start and the codes come back imediately. I have done a search both here and on google, but come up with inconclusive information.
The mini has the most up to date throttlebody and the customer insists the vehicle has had the engine harness replaced.
When I hook up my scan tool and monitor the tps value it doesn't change, so it appears the tps is faulty correct? well I replaced the tps and no change. I have also checked the harness connections and everything appears to be fine.
Does anyone have anyother suggestions on where to begin?
A little more info, the vehicle does have a uni-chip and a methanol injection system wired into it, both have been disconnected, but the problem still exists.
Old Aug 18, 2010 | 05:58 AM
rose0529's Avatar
rose0529
Bump, My mini threw both of those codes twice last night, I cleared them and seems fine now, but I am having trouble figuring why they were thrown and how to fix them. Anyone have any info?
Old Aug 18, 2010 | 06:59 AM
Martin Brenneke's Avatar
Martin Brenneke
p1125 and po638
Can't find code po638 in the mini diagnosis without guesswork book but p1125 seems to point to the throttle being monitored by 2 potentiometers bythe edr throtle plate. The edrmonitoring system can detect a jammed or binding throtle valve or a broken link spring. Hope this helps.
Old Aug 18, 2010 | 08:27 AM
rose0529's Avatar
rose0529
That helps a bit on the p1125, thanks. From what i can find this is P0638 BMW Throttle Actuator Control Range/Performance - Bank 1. Have any idea what that would be?
Old Aug 18, 2010 | 01:47 PM
williambmac
Ended up being the engine compartment wiring harness. There must be broken/corroded wires leading up to the pcm plugs. I can squeeze/flex the harness in that area and the vehicle will start and run, but if you hit a bump it goes back into limp mode, then dies and won't start. This will be my customers second engine harness.
Old Aug 19, 2010 | 08:57 AM
tgreene73's Avatar
tgreene73
same codes
Hi guys thanks for getting me started, I just received these same codes p1125 and 0p638 on my 06 mcs
Old Aug 20, 2010 | 08:36 AM
rose0529's Avatar
rose0529
Thanks for the help. When you squeeze/flex the harness is it near the Throttle Body plug? or where? I haven't any problems since I reset the codes, but it worries me a bit and I dont want it to get to the point of not starting! How much does a new engine wiring harness cost?
Old Aug 26, 2010 | 09:07 PM
shack0001's Avatar
shack0001
A little more fuel to the fire. My '04 S is throwing P0638 only. Is it possible I bumped a connection while installing the most sexy carbon fiber cowl vents or that I have water intrusion somewhere? I have driven it without a problem several time since that mod but had to limp home today. The only other thing I've done in the last few days is service the A/C.
Thanks,
tm
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
alistaircookie
Oct 8, 2015 10:52 AM
maniacalmorgan
38
Sep 29, 2015 04:56 AM
Sikness
R57 :: Cabrio Talk (2009+)
Aug 20, 2015 06:00 PM
