EML and Check engine light 06 MCS
Old Aug 11, 2010 | 08:37 AM
tgreene73's Avatar
tgreene73
I have a 06 r53 with 65k miles on it -has served me incredibly well for the last 4.5 years but today the eml light and check engine light came on and car lost power down to 20 mph.I am looking for suggestions on to what could be wrong -its been extremely hot and humid here( in NY) for the last month or so. had no warning signs but was sitting in traffic
Old Aug 11, 2010 | 09:17 AM
Agarwaen's Avatar
Agarwaen
You need to have the OBD code read. If you feel like driving the car, you can go to an Auto parts store like AutoZone and they will read the code, generally for free. If you do not want to drive, you will either have to have the car towed to a mechanic, or find one that will come to you. Once you have the code, it can tell you what is wrong. Also, when the engine cuts power like that, we call it "limp mode"
Old Aug 19, 2010 | 09:01 AM
tgreene73's Avatar
tgreene73
codes
P1125 and 0638 appears to be an issue with throttle cxontrol?? Which after searching some other posts appears to be most likely a wiring harness replacement??]
Old Aug 23, 2010 | 12:37 PM
tgreene73's Avatar
tgreene73
Fixed thanks to All
it seems the connection was loose on the cable itself which caused the car to read the error codes I disconnected and reconnected the wires then cleared the codes and everything is running strong.
Old Aug 23, 2010 | 02:38 PM
JumpingJackFlash's Avatar
JumpingJackFlash
Glad you fixed it. I had read other posts where that was all that was needed... a quick reseating of the harness plug.
Old Aug 30, 2010 | 11:49 AM
tgreene73's Avatar
tgreene73
ok sorry guys I am back, car is still running strong but SES light came on again coming up with same 1125 code. checked connections and they are all good REALLY dont want to go into the dealer-Thanks again
Old Sep 1, 2010 | 07:27 AM
JumpingJackFlash
It is possible the terminals in the harness plugs are dirty or corroded. Unplug it and check for signs of this. If dirty, clean with a can of compressed air. If corroded, the male ends should be easily cleaned with a brass brush. The female ends will be a bit more tedious. You will need a round jeweler's file. You should be able to find a set at an arts and crafts or hobby store.
Beyond this, it's possible the harness is defective and needs to be replaced.
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
massmini03
Aug 12, 2015 11:19 AM
truedrew
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
