Boot Trouble
Old Aug 4, 2010 | 03:52 PM
lord kinboat's Avatar
lord kinboat
Boot Trouble
Hi I am new here and hoping to find advise or stories of common experiences.
My Boot lid ( Trunk ) was out of allignment. I checked the hindge and found one had torn the body where it mounted. The whole stud and nut pulled right thru and left a nut size tear in the mounting point.
Has anyone had this happen? Is there a fix besides taking it to a body shop and getting it welded? Do these hindges stretch out over time?
Old Aug 4, 2010 | 04:27 PM
Porthos's Avatar
Porthos
Not happened to me but is it the upper or lower one?
Old Aug 4, 2010 | 06:25 PM
lord kinboat
It is the upper hindge which looks like the Picture below.
The stud on the hindge mounts through a hole and then the nut goe on under the roof panel. The nut pulled right through the body however.
I can see there being a lot of stress placed on these hindges because of the location of the rams. It is a poor design and I may be one of the first few people to experience it because of my cars year.
Old Aug 4, 2010 | 06:50 PM
SNEEEZY - Erika's Avatar
SNEEEZY - Erika
Rattle Can Queen!!!
Originally Posted by lord kinboat
...It is a poor design and I may be one of the first few people to experience it because of my cars year.
What year is your MINI?
Old Aug 4, 2010 | 07:23 PM
Crashton's Avatar
Crashton
I have heard of the boot hinge pins seizing & after time the hinge breaks in half. I have never heard of one ripping out out of the body shell by the bolt. I think you may be headed to the body-shop for a fix.
Old Aug 4, 2010 | 07:38 PM
Porthos's Avatar
Porthos
Can you take a picture I have some ideas running through my head.
Old Aug 5, 2010 | 07:15 AM
Crashton's Avatar
Crashton
You could try using a couple fender washers on each side of the roof where the bolt pulled through. My guess is that will not be strong enough for a lasting fix, but it's worth a try.
Old Aug 5, 2010 | 10:42 AM
lord kinboat
It is a 2002 mini. I did end up trying a washer in behind it. Getting in was indeed akward and I lost one washer down the frame. Whoopie !!!
The metal has lost its strenth, because of fatigue. I think I will end up doing a little MIG work. It is an ugly situation, I will try to post some pictures soon.
Old Aug 29, 2010 | 12:22 PM
lord kinboat
I finally took the boot lid off and took out the hinges. One wasn't moving at the pin and was actually bending back and forth.
So I guess the solution is to make sure that you always oil your hinges or to ask mini to stop welding them so tight on the pin.
gknorr
Dec 26, 2016 09:38 AM
navybsn
Oct 4, 2015 03:27 PM
vetsvette
Oct 2, 2015 05:32 PM
gknorr
Oct 1, 2015 09:20 AM
