R56 Its official!I got my S! Drop-in filter sound ?
Hey guys just got my COOPER S last-night ... its sick
Even though i didnt know i would be able to hear the blow off of the turbo.... i want to make it louder .... would a regular drop-in K&N filter make it louder ?
Someone correct me if I'm wrong but you can't hear any blow off in a stock MCS. It's the factory "noisemaker"
If you get a cold air intake for it, or a real blow off valve, then you could really hear it. Drop in panel filters never really made a difference for me.
I dont know much bout MCS's but i think the intake filter blowing off the compressed air is what makes the sound... so technically if u change the filter to a better one it may produce a louder sharper sound...
IWASHMYCAR
-Tell me more about this forge spacer and what it costs.
IWASHMYCAR
The filter wont blow off any compressed air, if thats what you were stating... its a one way street there
Forge is just a 1/2" spacer or so that you put in where the diverter valve is. You just have to pop off that intake tube that goes to the turbo and youll see where it would go.
Basically stock this diverter valve would recirculate and relieve the unused turbo pressure back through the system... This spacer essentially has holes which lets that pressure vent to atmosphere thus psssssh-ing when you shift.
Like a stock blow-off valve minus the aftermarket adjustability of a real blow off valve..
Says they are 80 bucks now...but they show up in the Marketplace now and then for much less.
http://www.forgemotorsport.com/conte...102&cat=020102
edit: they have a whole long explaination on the site lol
The FMDVMCS is a sandwich type adaptor that fits between the existing electrical solenoid and the turbo charger housing.On the Coopers S turbo, built into the turbocharger housing, is a bypass facility. This allows charge air to be recirculated around the turbo charger from the boost side back to the intake side. This recirculation path is opened and closed by means of an electrical connection from the engine management to a solenoid that is mounted on the turbocharger housing. As you accelerate , the turbo charger vanes are spinning and boost pressure is increased, literally blowing into the engine cylinders. Then when you change gear you take you foot of the accelerator momentarily, select the next gear, and accelerate again. As you take your foot off the accelerator the throttle valve to the engine closes. The problem here is that during this process the turbo is still spinning and the boost pressure that it is producing has no where to go. (This is a bit like putting you hand over a hair dryer so the air cannot get out) What happens at this point is the turbo starts to stall, the spinning vanes slow down (incurring alot of stress) and the boost pressure drops. When you open the throttle valve again by pushing down on the accelerator (demanding more power) the turbo has lost its momentum, boost pressure and there is a pause or a "Lag" before the engine is producing the required power once again. To combat this loss of power and stress on the turbo, a recirculation or diverter valve is used. On the Mini, when the throttle valve closes, the engine management opens the recirculation route around the turbo. This gives the charge air an alternative route and allows the turbocharger to keep spinning so that when you accelerate again there is no "lag" or waiting period. This system works well and is adopted by nearly all vehicle manufacturers on turbo charged petrol engine applications. The only downside to this system is that a turbo chargers produce heat. (The hot air that leaves a turbo is cooled by passing it through an intercooler before it enters the engine. The cooler the air the more power is produced. ) By recirculating the hot air back into the intake side of a turbo the temperatures increase. This is where the Blow Off or Dump valve plays its part. By expelling the charge air to atmosphere rather than recirculating it, you do not increase the intake air temperature but you do allow the turbo to keep spinning. The side effect which is unacceptable to most vehicle manufacturers is the noise of the valve expelling the air. By fitting the FMDVMCS between the existing solenoid and the turbo housing (this involves removing only 3 bolts) the air is re-directed to atmosphere rather than recirculated.
It should be noted that the engine management also uses this valve to decrease engine power when necessary. An example of this is by the (DSC) Dynamic Stability Control system. Although you would not normally hear this occurring, when a blow off adaptor is fitted you may well hear the air being expelled when the DSC operates (going to fast around a bend for example)
PhoR53
May 2, 2026 12:59 PM
Aug 19, 2015 12:51 PM
Aug 19, 2015 08:28 AM
