TMAP/MAP sensors
Old Jul 29, 2010 | 06:06 PM
Wakey05MCS's Avatar
Wakey05MCS
TMAP/MAP sensors
So I recently ordered a MAP sensor and when it arrived I had some confusion on where each sensor was located. So I went online and scanned various threads/diagrams and came to this conclusion: there is a possibility that the MAP sensor is shaped differently than the TMAP sensor? Both sensors that were in the car when i bought it are identical and the MAP sensor I received was identical to TMAP sensors I find in diagrams. But the MAP sensor in diagrams is shaped differently than the TMAP sensor. Are these diagrams just incorrect are MAP sensors and TMAP sensors identical in appearance?
Old Jul 29, 2010 | 07:44 PM
Fatherdeth's Avatar
Fatherdeth
No, look on the front of the sensors. They have different part numbers etched into them. While they look the same, they are different. If I recall, they have different connectors, but i might be mistaken. Unfortunately it's late, but tomorrow I can get you the numbers. Actually I posted the numbers in one of the threads a while back. But yeah, if you have the two sensors side by side, they look identical.
Old Sep 5, 2011 | 06:31 AM
HappyHam's Avatar
HappyHam
this might be a little late but they do look identical but on the MAP sensor connector pin 3 doesnot have a wire running from it
shorenetworks
Nov 4, 2019 06:18 PM
CRC
Dec 26, 2015 11:30 AM
sempaipaul
Sep 18, 2015 03:05 PM
Doc Pain
Sep 15, 2015 11:31 PM
Sep 14, 2015 12:48 PM
