LO sign on AC indicator
Old Jul 28, 2010 | 12:23 PM
toki999's Avatar
toki999
hey guys,
recently my car was at the body shop for a repair and it took about a month.
anyhow, when i got the car back yesterday, AC indicator said "LO" on it.
usually it shows outside temperature...
also, when i hit Auto, fan goes to the max blow, even outside temperature is low...
i'm going to take the car in for service anyway but i just wanted to know beforehand...
thanks!
Old Jul 28, 2010 | 01:31 PM
Minidrivr's Avatar
Minidrivr
It sounds like you're confusing the temp displays.
Are you referring to the temperature display inside the auto climate controls on the center console or the temperature display on the tach screen?
The one on the tach screen is the outside temperature. The one on the display in the center of the auto climate controls is the inside temperature. If that one is reading LO, you need to use the red/blue adjuster on the right to up it to what you want (like 70). With it set to LO, Auto will cause the fan to blow on max.
Old Jul 29, 2010 | 06:06 AM
schatzy62's Avatar
schatzy62
to add to what Minidrivr said.
LO means that you have turned the AC down to its lowest possible setting.
This is all explained in the "Owners Manual"
Alpha Motoring
Nov 10, 2015 07:08 AM
Alpha Motoring
Oct 1, 2015 10:30 AM
OldElvis
Tires, Wheels, & Brakes
Oct 1, 2015 06:21 AM
MiniSMan
Sep 29, 2015 06:38 PM
EVMini
Sep 28, 2015 10:20 AM
