timing chain tensioner....AGAIN
Old Jul 22, 2010 | 06:52 PM
CaMiniMe's Avatar
CaMiniMe
so i have a 2007 S i had the dreaded timing tensioner problem and MINI fixed it a few months ago. they were very aware of the problem and assured me that once fixed it would not come back. well now its back, and over the past few weeks its got progressively worse. so i have to take it in again to have it fixed and i was wondering if you guys can give me any info i can share with the dealership so this problem REALLY doesnt happen again just in case my dealership missed anything when they fixed it the first time? this rattle really is annoying and i dont wan this happening again for a 3rd time in a few months.
thanks
Old Jul 22, 2010 | 08:25 PM
Dr Obnxs's Avatar
Dr Obnxs
Mini has been saying that the latest fix
will fix it for good for years now. Just make sure that they use the latest service issue fix. The Cold Start Rattle thread has info about that....
Matt
Old Jul 22, 2010 | 10:40 PM
fishbert's Avatar
fishbert
Old Jul 22, 2010 | 10:42 PM
Rixter's Avatar
Rixter
Did they do the complete fix according to S IM 11 02 07?
Old Jul 28, 2010 | 07:09 AM
CHILI-TIME's Avatar
CHILI-TIME
Can someone confirm the "Death Rattle"
Same subject, different issue...
I have had my 2007 MC in twice for the "Death Rattle"
Both times I left it overnight so they could hear it at Cold Start.
Both times they claim they couldn't hear / find anything.
Being 45 minutes away from the dealer, I cannot just drive over there when I hear it, nor can I be there when they test drive it the next morning.
Is there anyone in the vicinty of Torrington, CT that could confirm what I am hearing?
I would really appreciate a second opinion before I head over to New Country for the third time.
Old Jul 28, 2010 | 07:50 AM
MINIdave's Avatar
MINIdave
It's hard to believe they won't just take your word for it after all the negative publicity this has garnered.....when I described what I heard (I only heard it about 3 times) my dealer said "Bring it in, we'll take care of it" and they changed the tensioner - that was 16K ago and I've never heard it since.
Wonder why some dealers are so reluctant to help their owners and others so pro-customer?
Old Jul 28, 2010 | 09:01 AM
Dr Obnxs's Avatar
Dr Obnxs
Cause..
some dealers are a-holes! I don't get it either. Maybe they have a high bar to clear for getting warranty work paid for.
Matt
Old Jul 28, 2010 | 09:41 AM
minimini482's Avatar
minimini482
I brought my car in to the dealer and was told this sound was no big deal and that all Mini's sound like this on cold start up... Whether thats true or not, I don't know.
Anyone else hear this knocking sound when first starting their car in the morning?
Old Jul 28, 2010 | 10:08 AM
MINIdave's Avatar
MINIdave
I've never heard that noise on any MINI, ever!
I can't believe they think that's OK!
Have you had your tensioner replaced? What happens when you rev it up, does it go away?
My noise did not sound like that, btw. Mine sounded exacly like what it was, a loose chain sliding against the case. A new tensioner cured it......
Old Jul 28, 2010 | 10:39 AM
jcauseyfd's Avatar
jcauseyfd
CHILI-TIME,
fwiw, my understanding is the cold start rattle/timing chain tensioner issue only affects S models.
But I feel your pain about hoping the service tech will hear the same thing you hear.
Old Jul 28, 2010 | 01:03 PM
todoubled's Avatar
todoubled
2 tensioners replaced and ill put money on it it will be back when it gets cooler out
Old Jul 28, 2010 | 08:05 PM
pillar's Avatar
pillar
Is it me or does it sound like something is seriously loose... Whens the last time you got an oil change?
I remember when my oil filter wasn't on properly and i was losing oil by the second... it only took a few min b4 i heard that similar sound.
Everybody that works/owns a mini knows that isnt a "normal" sound... stupid dealership
Old Jul 28, 2010 | 08:18 PM
Oxybluecoop's Avatar
Oxybluecoop
So you have a death rattle on a NA N12 Cooper? While it's entirely possible since they have the same tensioner setup as the MCS it's not something I've heard of before. Do you by chance have any video of this to share?
Old Jul 29, 2010 | 05:42 AM
minimini482
I haven't had my tensioner replaced. When I brought it in to the dealer, I thought thats what they might do, but they said this was a 'normal start up sound'. When I rev it, it does go away. After searching some other You Tube vids, I found this one posted by another NAM member who has the same sound on cold start idle. Only difference is when he revs his engine you can tell something is def wrong/loose.
I just did an oil change about 200 miles ago; I have checked the oil filter and drain plug several times for leaks but everything seems to be fine. I added 4.4 quarts of oil and the level is right in the middle of the dip stick. I guess all I can do is monitor it and if it gets worse, take it back in.
I have read here that that these cars do need oil added to them between oil changes, so maybe Ill have to add some sooner rather than later?
Old Jul 29, 2010 | 01:52 PM
tvrgeek's Avatar
tvrgeek
Dealers don't need to hear it. They have a procedure for specific measurements. I have seen the sheet. If they fail to do this, then they are at fault.
Old Jul 29, 2010 | 02:04 PM
jcauseyfd's Avatar
jcauseyfd
They need to hear the problem to decide whether checking the chain tensioner is going to be part of the diagnostic procedure.
09R56
Nov 16, 2022 10:49 AM
TREX
Nov 2, 2019 07:31 PM
Svejk
Feb 24, 2019 12:18 PM
scottrn
Aug 22, 2015 07:26 PM
iamcamkeenan
Aug 10, 2015 03:31 PM
