Driver Window stopped working out of nowhere...
Old Jul 20, 2010 | 08:49 PM
Un0RiGiNaL's Avatar
Un0RiGiNaL
So i have my door panels off cause i installed speakers and stuff. I didnt do any harm to the window motor or anything..
anyways so today out of nowhere it just stopped working. I hear the click but no movement. I didnt touch anything it just stopped working. What could it be??
I need that driver side window to open cause i hate the AC..
What could it be and how can i diagnose it? I only have 44k miles on the car..
im going to check the fuse tommorow hopefully its just the fuse.. but can fuses just blow out of nowhere?
Old Jul 20, 2010 | 09:35 PM
Eric_Rowland's Avatar
Eric_Rowland
It's not uncommon for windows to stop working. Poor man's fix is to hold up the toggle, and simultaneously hit the space on the door in between the speaker and the handle.
Then again, if you recently worked in the area, it could be a physical connection issue.
Old Jul 20, 2010 | 09:39 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes beat on the door while holding the switch until it works. If that doesn't work you'll need a motor. I keep em in stock just for that reason.
Old Jul 20, 2010 | 10:31 PM
Un0RiGiNaL's Avatar
Un0RiGiNaL
Just in case beating on the door does not work, link to the motor?
Old Jul 21, 2010 | 03:10 AM
NightFlyR's Avatar
NightFlyR
Very common, Open door, Slam door closed, just as the door is slamming hit the toggle switch, mine get stuck all the time in the summer months.
Old Jul 21, 2010 | 06:27 PM
Un0RiGiNaL's Avatar
Un0RiGiNaL
slamming door while hitting switch worked.
thanks guys, saved me $$$
Old Dec 23, 2018 | 04:08 PM
JDM_'s Avatar
JDM_
If this method works... Does it mean the motor is going bad?
This method works for mine but my window is getting stuck more often.. I want to fix the root issue.
Old Dec 24, 2018 | 11:28 AM
Eric_Rowland
If it continues to misbehave, you either need to clean out or replace the motor.
Old Dec 24, 2018 | 01:37 PM
JDM_'s Avatar
JDM_
Thank you.. I ordered a new motor and the tool needed to take the window out today. Does anyone know where I can get the weather stripping/ window scraper that touches the window inside and out? My window squeaks when it goes up and down due the the weather stripping wearing out.
Im having a hard time finding this part online.
I fugute if I’m taking it apart I might as well replace it.
Old Dec 31, 2018 | 08:52 PM
Deadhead72's Avatar
Deadhead72
Search YouTube because you can clean the motor barrel and it will work fine. Fix costs no more than some 800 grit sand paper.
Old Jan 1, 2019 | 05:28 PM
JDM_'s Avatar
JDM_
Cool!
Is this a Mini specific video or a general video on repairing window motors?
W0TM8
Dec 19, 2019 07:50 AM
Dec 23, 2015 10:36 AM
maestro39
Oct 27, 2015 02:38 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
