fluid-filled engine mount - question
Old Jul 19, 2010 | 06:46 AM
JAB 67's Avatar
JAB 67
The fluid-filled engine mount on my 2004 MCS has barfed its guts out at 96K. Will replace with OE. Various posters have claimed it is necessary to remove wheel and wheel well liner to gain access. True? Seems to me that as long as I can get underneath (with ramps or jackstands) to remove the female 12 mm Torx that goes through the frame rail that I should be OK. Anyone with experience? TIA.
Old Jul 19, 2010 | 11:13 AM
HoustonCoog's Avatar
HoustonCoog
I just replaced mine this past weekend. I didn't remove the wheel but I did put my car on jack stands and removed some screws around the liner to allow for easier access to the Torx bolt underneath. If you can get to it without removing the liner then go for it, for me my car is entirely too low to get underneath so I used the jack stands and I just removed 5 of the plastic screws around the liner to be able to peel it back some.
Alkaidovich
Jan 30, 2021 01:35 AM
W0TM8
Dec 19, 2019 07:50 AM
silence2-38554
Nov 12, 2015 09:39 AM
Mini'mon
Aug 16, 2015 12:47 PM
