HELP! My Mini is Broken!!
Old Jul 18, 2010 | 07:26 AM
jamiebean1980's Avatar
jamiebean1980
I purchased a 2004 used Mini with 75k miles last October from a local dealership. In April 2010 the PowerSteering quit working and I chose to park her instead of fixing bc I was trying to buy a house. A few weeks later I went to move it and the Power Steering worked and has been fine since! Last night I went to start the Mini and NOTHING. After hooking up to another car to jump she started getting some juice but would NOT take a jump start!
Has anyone experienced this? Or have ANY idea what could be wrong?
Old Jul 18, 2010 | 08:32 AM
miniblucabrio's Avatar
miniblucabrio
I'd say start with a new battery. that will probably solve it for you.
Old Jul 18, 2010 | 08:38 AM
Sidewalksam's Avatar
Sidewalksam
I agree take the battery out and have it tested. If its bad replace if its good recharge using a charger and try again.
if it starts try checking the voltage across the battery terminals to make sure your alternator is doing its job.
how long did the car sit between starting and not starting?
Old Jul 18, 2010 | 09:14 AM
IMAMINI's Avatar
IMAMINI
I agree, sounds like the battery. Cheap enough fix but have it tested first at a reliable station or mechanic.
Old Jul 18, 2010 | 10:34 AM
RobertJ's Avatar
RobertJ
Sitting for an extended period could have wrecked the battery. That'd be my guess too.
Old Jul 18, 2010 | 10:49 AM
MINIdave's Avatar
MINIdave
I don't think the MINI likes to be jumped, I've never had any luck doing it.....take the batery out, have it charged, tested, then charged again.
The power steering situation is a whole nother matter, it's powered by a brush type DC motor and those brushes wear out, when they do and stop making contact, the power steering doesn't work.
Also, the power steering has a cooling fan, if it quits and the power steering heats up, it will shut down till it cools off again.
Likewise, if the fan fails and blows the fuse, it can shut down the power steering. You have a number of possibilites, you either need to go to the dealer or to a good independent in your area who is familiar with MINIs to get this solved.
Old Jul 18, 2010 | 05:06 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yup sounds like you need a battery.
Be on the watch, the P/S will probaly die again. It's pretty common for them become intermitent, if that is the case it will need to be replaced.
Old Jul 23, 2010 | 06:40 AM
ajv915's Avatar
ajv915
oops
Last edited by ajv915; Jul 23, 2010 at 07:59 AM. Reason: I was mistaken in the location of the PS pump for the MC
Old Jul 23, 2010 | 07:41 AM
puresilvermcs2002's Avatar
puresilvermcs2002
Buy a Black and Decker battery charger ( I'll suggest the automatic) and charge you battery. The chargers are good also for regular maintenance, as your car alternator is kind of a fast charge and in order to extend the life of the battery it is good to do a "slow" charge ( 6-12hrs). Check the battery indicator sight ( green = charged, black=needs to be charged, yellow=battery replacement)
09R56
Nov 16, 2022 10:49 AM
Motown
Apr 20, 2018 09:31 AM
Ovrclck
Aug 27, 2015 07:58 PM
dchang0
Aug 10, 2015 03:37 PM
minipopkart
Aug 9, 2015 12:13 PM
