Steering Lock Warning Light Question
Old Jul 10, 2010 | 02:10 PM
BIMMINI's Avatar
BIMMINI
Coordinator : Se7en Cities MINI (C7M)
My neighbors daughter is traveling in upper New England and just phoned home to say that she had a warning light come on which looks like a steering wheel with a padlock on it. This is on an '07 Cooper automatic. I've done some searching but I haven't yet found the significance of this light, what it means, and what she should do about it. The dealers service departments are are all now closed for the weekend and she needs to get from Burlington Vermont to Portland Maine on Monday. Do any of you know what this light signifies, why it came on, and weather or not it's okay for her to continue to drive the car prior to taking it in for service to have it checked out? If any of you have an owners manual handy, or have experienced this issue, I would appreciate hearing about this light.
Old Jul 10, 2010 | 03:17 PM
Btwyx's Avatar
Btwyx
My 07 manual says:
Lights up in red:
Electric steering wheel lock malfunc- tioning
The engine can no longer be started. If applicable, do not switch off the engine. Contact your MINI Dealer.
Lights up in yellow: Electric steering wheel lock engaged
Move the steering wheel before start- ing the engine.
Old Jul 10, 2010 | 03:52 PM
RJKimbell's Avatar
RJKimbell
Or...if the Display shows an Exclamation Mark to the Right of the Steering Wheel it means that the Power Steering has failed.
"You can continue your journey, but moderate your speed and excerise due caution. Steering response will be markedly different. Have the system checked without delay."
Quoted from the 2008 Owner's Manual for MINI and MINI Clubman.
Old Jul 11, 2010 | 06:00 AM
ellinara's Avatar
ellinara
This happened to me when I had my coasting in neutral and the engine was off (start/stop function)... Pressed the clutch causing the engine to start and warning disappeared.
bneer
Jul 15, 2019 04:41 PM
Dec 23, 2015 10:36 AM
JamJam43087
Aug 16, 2015 02:02 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
