How To Suspension :: Rear Trailing Arm Bushing Insert Install
Old Jul 9, 2010 | 06:59 PM
R53Warrior's Avatar
R53Warrior
So I ordered these a couple weeks ago and when they showed up today I braved the 95* weather to install them. I originally got them to try a cure a tire rubbing I am only getting on the passenger side when I get a sharp impact. The other issue I was having was the back end becoming very vague and 'floaty' on off camber turns. I read through the installs that people have done before and honestly it is much easier than any of them sounded. It took me 55mins from the time I put the jack under the car till I put away my torque wrench after doing the lug nuts. Here is brief write up. It is very straight forward.
Here is the front of the rear wheel liner you need to pull back. There is a phillips head screw on the sideskirt that holds the bottom.
Remove this 10mm plastic nut to get more clearance
Here is the bolt that holds the trailing arm to the alignment/unibody connection. Its 18mm, I used a 3/8-1/2 conversion so I could use my bigger breaker bar. With just a 18mm socket the angle would be even better.
After removing the bolt the trailing arm will sag slightly giving more than enough room to get the bushing into place. I used a detailing brush to clean out the voids in the stock bushing but even with 86k miles it was just some dust.
Getting the powerflex inserts into place is the only thing that is a little fiddly. They fit in to the voids but like some of the motor mount inserts they are slightly oversized. What I did was get the entire lip of the insert seated in the void then as I tightened the bolt back down it fully seated into the OEM bushing.
Overall very easy install. For the price and ease of install I don't really see a down side. Installing the poly upper shock bushings would probably complement this. I am looking forward to doing the front LCA bushings now.
Old Jul 9, 2010 | 07:10 PM
user 7082082's Avatar
user 7082082
Good job. I will be doing this soon as well. How do you like the feel of them?
Old Jul 9, 2010 | 07:13 PM
R53Warrior's Avatar
R53Warrior
I like it. It makes the rear end feel like I upped the dampening on the shocks. Also the tail-end feels more accurate when going around sweepers. So basically more connected, which is good haha
Old Jul 9, 2010 | 08:05 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Good write up, these rear trailing arm bushings are an easy install, with good gain.
Old Jul 10, 2010 | 09:22 AM
wrh3's Avatar
wrh3
Thanks for the write-up
Old Jul 10, 2010 | 10:41 AM
jimz68's Avatar
jimz68
Thanks for this. I know what I'm doing next weekend!
Jim
Old Jul 10, 2010 | 12:58 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Cool. Now do a write up with the pre 5/2003 build date trailing arm design.
Pre-5/03
Rear Trailing Arm Front Support Insert PFR5-110
5/03+
Rear Trailing Arm Front Support Insert PFR5-1102
It's ok though. I might just save this one for when I replace the whole bushing carrier, or if someone releases solid bushings, and not just a void insert.
Old Jul 10, 2010 | 02:13 PM
R53Warrior's Avatar
R53Warrior
Looking at it idk if it would really be any different. Looks like it would have the same placement but just a different sized bushing insert. I could be wrong.
Old Jul 17, 2010 | 07:08 PM
jimz68's Avatar
jimz68
Installed mine today.
I like 'em! There's a nice fast sweeper on my local twisty road that has a bump right in the middle of the corner. Before, the back end would get a bit un-settled over that bump, but with the new bushings it stayed stuck. Nice!
I used a piece of coat hanger to make a hook to keep the inner liner bent out of the way.
Thanks Again!!
Jim
Old Jul 17, 2010 | 07:43 PM
R53Warrior's Avatar
R53Warrior
Awesome! Pretty much the same results I had.
Old Jul 18, 2010 | 09:54 AM
Raiyu's Avatar
Raiyu
I'm just over 60k miles and have been considering doing a bushing refresh, would I be best off replacing the whole bushing with a new one or will just doing the insert suffice?
Old Jul 19, 2010 | 07:22 AM
jimz68's Avatar
jimz68
I have over 204,000 miles on my car, and the bushings looked fine. You should be good to go with just the inserts.
Jim
Old Aug 12, 2010 | 08:20 PM
agranger's Avatar
agranger
I just got in from doing the rear bushing install on my '06 MCS. One side it was really hard to realign the 18mm headed bolt... I probably spent half od my time getting that one bolt in. I finally hooked up my air ratchet so I could easily turn the bolt while fiddling the trailing arm about and it popped right in.
Old Sep 14, 2010 | 06:25 PM
jimz68's Avatar
jimz68
When I installed my bushings on 7/17, I used the lube supplied by Powerflex. Well, now they are a squeakin'.
Anyone else? We have a few different types of lubes/grease in our shop, just trying to figure out which one to try next.
Jim
Old Oct 9, 2012 | 01:28 AM
sujeemini's Avatar
sujeemini
Looks like my rear bushing are shot and one of them is making a knocking noise. Is it ok to just install these inserts along into the worn bushings?
Or should I purchase new OEM bushing and then install these ?
Old Oct 9, 2012 | 07:17 PM
R53Warrior's Avatar
R53Warrior
well, check how damaged they are. If they are starting to crack I would replace them. The inserts supplement the bushings they dont replace them. Also check to make sure its that bushing and not blown endlinks or lower or upper control arm bushings.
Old Oct 9, 2012 | 07:27 PM
sujeemini's Avatar
sujeemini
Great! I guess I'll replace the training arm bushings then. I have almost 174000 miles on my car. And reading through the forums it seems they need to be replaced at around every 100000 miles. I'll check on the upper and lower control arm bushings as well. I replaced them then end-links when I installed my coil-overs.
Is it easy to take the old bushings out? Pelican parts have 2 options for me. One with just the bushing, and one with bushings already pressed...
Old Nov 30, 2014 | 10:38 PM
climbingaggie03's Avatar
climbingaggie03
Do you need to get an alignment after putting these in?
Old Dec 1, 2014 | 08:08 AM
R53Warrior's Avatar
R53Warrior
I don't see why you would need an alignment
Old Dec 1, 2014 | 10:52 AM
wellzy's Avatar
wellzy
Its best to get an alignment after taking any suspension apart.
Toolman
Jan 20, 2016 06:50 AM
wkp1219
Nov 13, 2015 07:52 AM
maestro39
Oct 27, 2015 02:38 PM
Minibeagle
Aug 13, 2015 10:00 AM
