R56 16x9, will they fit?
Jul 4, 2010 | 11:51 PM
I have always been into the stretched rubber look. Need your help!
http://www.mirowheels.com/STP1.html here are the ones i'm looking into.
I am thinking 16x9 on all 4 corners. My ride has H&R lowering springs right now for the MCS.
Is this possible to fit these without any serious mods? The offset is 30 on these rims. I will also be looking to stretch my tires, and if anyone has any considerations on sizes for this as well.
Jul 5, 2010 | 12:56 AM
Yep.
16x9 et30 all around. It comes close on the inside, but they fit no problem.
Jul 5, 2010 | 06:57 AM
mmm Schmidts modernlines!
More pics please!!!
Jul 5, 2010 | 07:08 AM
Jul 5, 2010 | 08:04 AM
when the tire is stretched onto a wider than intended rim, does that create any risk of sudden deflation during an emergency maneuver?
pardon my ignorance,
Charlie
Jul 5, 2010 | 08:46 AM
id think youd be more at risk on improperly inflated "regular sized" tires vs. stretched tires... Ive had a low tire dismount on a sharp turn before.
Theres a lot of variable, but in the end, yes, of course its not as safe as a properly sized tire/wheel combo... are tires going to go deflating all the time, probably not... Not something youd track either
Jul 5, 2010 | 09:25 AM
Quote:
Originally Posted by
soytea
Yep.
Sweet! What is your set up? What tire size should i use for a 16x9.
Jul 5, 2010 | 09:42 AM
cmt52663
No.
Jul 5, 2010 | 10:15 AM
Just found out the MIRO wheels i want in 16x9 comes only in an offset 15.
Will they still fit?
Jul 5, 2010 | 10:17 AM
et15 is alright in the rear, albeit pretty extreme. Up front, it's probably too low of an offset for our cars.
Jul 5, 2010 | 10:20 AM
... I'm trying to find my bookmark for the -20 mm spacers. I know I saw them advertised somewhere...
Jul 5, 2010 | 10:48 AM
cmt52663
Joke? Spacers lower the offset, not raise them and a negative spacer would be impossible to physically create.
The only way to raise the offset of a one piece wheel is to mill off the hub face, but that's usually only good for 3-5mm.
Jul 5, 2010 | 11:58 AM
soytea
Yep.
nice choice color
is that an after market roof rack?
Jul 5, 2010 | 05:55 PM
The full setup was V-Maxx coilovers / 16x9 et30 Modern Lines / 205/45/16 Falken 912s
Yes, that is a Yakima roof rack with 2 copper head bike mounts.
I just sold the Schmidts today...
Jul 5, 2010 | 06:18 PM
Rally@StanceDesign
Joke? ...
Uh, yessir - that's what passes for humor around here. Sad but true.
Jul 5, 2010 | 06:39 PM
cmt52663
Just had to make sure. I've had some interesting PM inquiries about spacers to raise offsets in the past. You never know around here
trw92a
Aug 26, 2015 01:47 PM
Aug 25, 2015 07:11 AM
Aug 19, 2015 12:51 PM
Aug 12, 2015 01:24 PM
