A tire question for sprinted/aggressive drivers
Old Dec 5, 2003 | 09:02 AM
koolmini's Avatar
koolmini
There’s probably thread on this already, but I’m gonna ask anyway
I’m assuming that the really aggressive drivers are running aftermarket tires
How many miles are you aggressive drivers getting out of your aftermarket tires
(no runflats please)
I’m a really aggressive driver and I have Yokohama’s AVS-ES100’s, I have 10,000 miles on them (I rotated them at 5000) and their starting to look really weak
_________________
Old Dec 5, 2003 | 09:58 AM
ColoradoMark's Avatar
ColoradoMark
My Kumho MX's have about 4500 miles on them and they are about toast. This mileage includes probably six autocrosses and four or five track days.
Old Dec 5, 2003 | 10:05 AM
dominicminicoopers's Avatar
dominicminicoopers
>>I’m a really aggressive driver and I have Yokohama’s AVS-100’s, I have 10,000 miles on them (I rotated them at 5000) and their starting to look really weak
I've got the same tires (16&quot with nearly the same number of miles (mine are around 12K miles now) on them as well as the rotation @ 5K and now @ 10K. The ones that I just moved from the front are nearly down to the wear indicators. The right side is much worse than the left side for some reason. The ones from the rear moved to the front, has probably another 5k miles. So I'm looking at about 17k miles out of them. Buy, hey, they're performance tires and there's cheap (relatively speaking for performance tires) too.
Old Dec 5, 2003 | 10:10 AM
goin440's Avatar
goin440
I don't consider myself an aggressive driver, but I too have AVS ES100s. Before I put them up for winter I've run maybe 15000 miles on them. Looking at them, I give another good 3000 or so. My wet traction (from the looks of depth) is going to get pretty weak though.
Old Dec 5, 2003 | 10:11 AM
kenchan's Avatar
kenchan
really depends on how/where/wat temps you drive. i had a 98 prelude
with Dunlop SP8000's that had to be changed every 3k miles because i
took it out to malibu every weekend when i lived in LA.
Old Dec 5, 2003 | 10:34 AM
koolmini's Avatar
koolmini
good
so it's not just me
_________________
Old Dec 5, 2003 | 12:24 PM
kenchan's Avatar
kenchan
:smile:
but for street, you don't need super sticky tires on these cars, the suspension
is well balanced. its only when you start doing the initialD stuff in the canyons
where you need sticky tires, i guess. the dunlop SP8000's have been my
favorite tires until i began using S03's by bstone.
Old Dec 8, 2003 | 04:30 AM
koolmini's Avatar
koolmini
^^^i heard good things about the S03's
AVS sports?? by yoko??
Old Dec 8, 2003 | 04:43 AM
sndwave's Avatar
sndwave
Coordinator :: Gulf Coast & Panhandle MINIs
Yes the ES 100's. Andrew's been using them and seems to like them alot. I was going to put some on when I get my new wheels this next week.
Old Dec 8, 2003 | 05:00 AM
d-mini-ero's Avatar
d-mini-ero
They are a bit pricey..... but the Toyo T1S's(215/45-17) are ... a terrific sticky summer tire. And.....
if ya need something for this winter the Blizzaks are...awesome
Peace,
D
Old Dec 8, 2003 | 09:37 AM
koolmini's Avatar
koolmini
Pat,
i know, i run the ES-100's too (see my first post at the top)
Andrew has 215/45/17 and i run 205/45/17
(got to ask him if they rub, i want wider tires too
_________________
Old Dec 8, 2003 | 09:53 AM
sndwave's Avatar
sndwave
I’ve never had Andrew say anything about rubbing and we’ve talked about his setup a couple times. You may want to ask him anyway.
Old Dec 8, 2003 | 10:08 AM
kenchan's Avatar
kenchan
yep, Yokohama Tires make the AVS Sports. very nice grip.
S03's are by Bridgestone.
Old Dec 8, 2003 | 10:20 AM
Yucca Patrol's Avatar
Yucca Patrol
No rubbing whatsoever with my 215/45/17 YokohamaES-100's with stock suspension.
So far, I have about 3000 miles on them, including one weekend of spirited driving at the Tail of the Dragon. The fronts are beginning to show wear, especially on the outside corners, and with rotation, I expect to get about 10-12k out of this set of tires.
These are great tires for spirited street use on dry roads. Wet traction is less than I would expect from a set of all-seasons, but acceptable in a climate that does not get significant snow/ice during the winter.
With the way I have seen you drive, koolmini, you should be happy to get 10-12k on a set of performance tires
_________________
B.A.M.A. (Birmingham Area MINI Association)
Old Dec 8, 2003 | 10:57 AM
koolmini's Avatar
koolmini
Old Dec 8, 2003 | 11:02 AM
koolmini's Avatar
koolmini
gonna get a new set of 215/45/17's in the spring
wondering if i can push it to 225/45/17's ?????
also wondering if i should try a diferent tire, as well
is there anybody else out there that wants to speak-up with their proformance tire experiences?
Old Dec 8, 2003 | 11:05 AM
d-mini-ero's Avatar
d-mini-ero
>>Dennis
>>Toyo's??? how pricey (especially if i'm gonna burn em up in 10,000 miles)
>>:D
They were about $170-(paid cash).... locally.
Peace,
D
Old Dec 9, 2003 | 04:19 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
For Yoko ES100 the most miles I have read owners got is about 20-22K but I am sure that is not with really aggressive driving. So there is potential for decent wear. Rotations every 5000 miles and good tire pressure and alignment all will help.
I would advise sticking to 215/45-17 or you can get some rubbing depending on your suspension.
Talk to alex@tirerack
Toyo T1S are about $150-160 discounted over the internet and are good tires. Tirerack doesn't carry them.
Bridgestone Potenza Pole Position S-03 are heavy but perform very well in wet or dry. Cost about $163 each and wear about the same as ES100.
Goodyear Eagle F1 GS-D3 are new and replace the D2 (worth a look and at tirerack)
http://www.tirerack.com/tires/tests/gy_f1_gs_d3.jsp
http://www.tirerack.com/tires/tests/...d3_charts.html
Randy Webb likes Falken Azenis Sport for autocross/street- performs well but doesn't wear as long as ES100.
Another performance tire by Yokohama is the Parada Spec 2 and while it performs well it is noisy and doesn't wear as well-maybe 12K miles.
Your best performance on many tires will come after about 800 miles of use and by a little more than half of the tread life gone might start to loose performance. Don't wait until your tires are really worn before considering replacing them as worn tires don't offer decent performance anyway.
http://www.tirerack.com/tires/tirete...eplacewhen.htm
_________________
Aloha
Old Dec 9, 2003 | 04:48 AM
koolmini's Avatar
koolmini
minihune.......thanks
considering that i'm going to drive the rubber off these tires (like the last set)
Old Dec 9, 2003 | 05:10 AM
minihune's Avatar
minihune
Old Dec 9, 2003 | 06:52 AM
koolmini's Avatar
koolmini
>>If you are staying with Yokohama ES100s then another tire size to consider is 215/40-17 but it has a slightly lower load rating and slightly rougher ride but more aggressive 40 series look.
>>I have ES100 in 215/40-17 and think that it is a good choice.
minihune.....thanks again
but "rougher ride"= bad in the Northeast (NY)
........the roads here suck! just ask my old Perelli's side walls
_________________
Old Dec 12, 2003 | 06:51 PM
GrFa's Avatar
GrFa
I am a little late to chime into this thread. Excuse my lack of posts but I just came over from MINI2. I too run Yoko ES100 in 205/45/17. I had them on for about 4500 miles give or take before switching to my winter wheels and tires. Most of it was warm summer, around town driving. The front tires have maybe 30% tread left. The rears look almost new with the lines along the edge still partly visible. They are all very evenly weared but used hard. I am looking at selling what is left of them and my s-heavies and getting some light 16s. Right now with 15x5.5 cooper wheels with 175/65 tires the car is downright fun. I cannot believe how well it handles. More than fun for the winter months.
Old Dec 13, 2003 | 01:05 PM
Zeede's Avatar
Zeede
Out of curiosity, how long did your runflats last for all of you?
Old Dec 14, 2003 | 12:03 PM
GrFa's Avatar
GrFa
I took my Goodyear Eagle RS-A runflats off after only 1500 or so miles and they looked brand new. Sold them to Great-Gro and I believe he got over 20k miles out of his before he bought mine. They will last a long time, at least the all season goodyears will.
Old Dec 14, 2003 | 12:23 PM
koolmini's Avatar
koolmini
what did Great-Gro corner the market on low milage Goddyear RSA's
