Question - dash panel to right of HVAC temp controller
Old Jun 25, 2010 | 08:13 AM
jujucooper's Avatar
jujucooper
I've searched, and I find info on dash removal, but I guess this isn't really the dash I am talking about.
Picture this: I have a car with the manual a/c. On the right side there is a wheel for temp control. Just to the right of that wheel (the wheel almost sits in it) is a plain black panel that runs north/south. At the top of that panel it seems to run under the center speedo/hits the panel where the glove box button resides.
I think my rattle/buzz is coming from there because I can often press on the top of that vertical panel and it will stop. Only if I press it where it meets the other panels, at the top, under the speedo.
Can I take that north/south panel off myself? If so, has anyone done it? I'd like to stick some felt or stuff in at the top of it I think.
Thanks!
Old Jun 25, 2010 | 11:16 AM
irontree's Avatar
irontree
Disconnect the battery.
Remove the two screws holding the tach and move it out of the way.
Remove the left dash trim
Remove the right dash trim
Remove the two covers on the dash vent.
Remove the two screws under the covers that were removed.
Remove the screws that hold the cover for the large gauge.
Remove the side panel
Remove side panel
Remove the front panel
Old Jun 25, 2010 | 12:39 PM
jujucooper's Avatar
jujucooper
Thanks for the pics!
Old Jun 25, 2010 | 02:34 PM
irontree's Avatar
irontree
I hope this helps.
Old Jun 26, 2010 | 05:20 AM
richardsperry's Avatar
richardsperry
Where did you get those pics from a manual? Or better yet, where can I get them...lol
Old Jun 26, 2010 | 05:31 AM
irontree's Avatar
irontree
The pics come from the BMW TIS.
Old Feb 13, 2012 | 06:23 PM
Performance Angst's Avatar
Performance Angst
Irontree:
Do you have the steps to remove the lower glove box front cover? I hit a brick wall trying to get it out.
eatsleepautox
Oct 30, 2015 06:46 AM
tylewis
Aug 18, 2015 06:53 AM
Emnotek
Aug 13, 2015 05:47 PM
mini yellow-haa!
Aug 13, 2015 11:18 AM
