R50/53 Does the ScanGauge2 have peak recall?
Old Jun 11, 2010 | 11:04 AM
plasticknives's Avatar
plasticknives
I was curious as to whether the SG2 can display peak readings? I was going to pick one up to monitor boost and water temp but would really like that feature.
Thanks all.
Old Jun 11, 2010 | 11:20 AM
thulchatt's Avatar
thulchatt
Peak temp but not boost.
Also top speed and RPM.
Old Jun 11, 2010 | 04:56 PM
plasticknives
Thanks.
Another question for SG owners.. Is the slow refresh rate annoying when trying to monitor boost readings or is it acceptable?
Old Jun 11, 2010 | 11:24 PM
Some Guy's Avatar
Some Guy
I guess it depends on what you are trying to do. Once I found out that my boost peaks at 23psi I stopped using that setting mostly. If I wanted to do monitor something I would do some logging with a laptop.
Old Jun 12, 2010 | 08:05 AM
plasticknives
Is this pretty much the refresh rate on a Mini?
http://www.youtube.com/watch?v=hq2RrYfp-v0
Old Jun 12, 2010 | 09:12 AM
onefish2's Avatar
onefish2
I had the Scangauge II in my car for quite some time. I followed the directions to add boost as an xgaguge. But I never liked it and the refresh is not that great. There is no comparison to a true boost gauge. And I found that out now that I have the VEI Systems high resolution boost gauge.
http://www.veisystems.com/bhm-m.html
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
Pedro99
Oct 3, 2015 10:56 AM
TBRoye
Sep 29, 2015 06:49 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
daviday
Sep 25, 2015 01:31 AM
